Stock oem ITR valve springs seat pressure
Old Jan 22, 2009 | 11:45 PM
Dom_GsR's Avatar
Default Stock oem ITR valve springs seat pressure
Hi,
I have some ITR valve springs on my boosted B18C1 for 5 years now at 16-18psi 9100rpm fuel cut and managed with AEM EMS. I think I should go with stronger springs but I would like to know what is the seating pressure of OEM ITR springs? I'm running Skunk2 stage1 cams. So what is the stock ITR spings pressure at seat and at peak so I can compare with skunks2 springs...
Thanks for your help
Old Jan 26, 2009 | 02:50 PM
Dom_GsR's Avatar
Default Re: Stock oem ITR valve springs seat pressure
anyone?
Old Jan 27, 2009 | 06:00 AM
19slocivic97's Avatar
I looked at the vavle train specs from acura and it doesnt specify pressure. The only specs for springs are height...
Old Jan 27, 2009 | 01:55 PM
Echo7847's Avatar
https://honda-tech.com/forums/showth...ht=test+spring
Old Jan 27, 2009 | 03:03 PM
Dom_GsR's Avatar
Thanks you
Can the seat pressure of 50lbs of the tuner series from skunk2 is enough for to keep the valve closed to prevent back pressure from coming back in from the exaust valves at 20psi?
.adam.
Oct 24, 2014 09:56 AM
mr.speaker
Jan 18, 2011 02:02 PM
HatchSpeeD
Apr 9, 2006 05:52 PM
