Civic HX, I have a hesitation around 2500 or 3000 RPM, what is wrong?
Old Aug 7, 2002 | 04:28 AM
pechetico's Avatar
Default Civic HX, I have a hesitation around 2500 or 3000 RPM, what is wrong?
I have had this civic for the past 3 years and all of the sudden it start having this hesitation around 2500 or 3000 RPMs or when the green light for the "Change Shith" comes on. what is wrong with this? is it the cpu? I took it to the dealer and they told me that the spar plugs where to hot for the engine (Bosh Platinum) so I change them, and it did not work. Some times when I'm on the higway and I'm doing around 55 to 60 mph and 2700 RPMs the car start the hesitation by it self and you can see the stick sifht jumping. Does anybody have a suggestion? what can I do to fix this? Thanks for your time.
Gerardo
Old Aug 7, 2002 | 07:55 AM
Replica's Avatar
Default Re: Civic HX, I have a hesitation around 2500 or 3000 RPM, what is wrong? (pechetico)
Timing? My car does that but my timing is set way back for the jrsc. Maybe you should check your timing.
Old Aug 22, 2002 | 04:30 AM
pechetico's Avatar
Default Re: Civic HX, I have a hesitation around 2500 or 3000 RPM, what is wrong? (Replica667)
I have try the timing problem and it is in the specifications. Is it correct that the valves can create that kind of hesitation? my shop did the timming belt, the distributor, but I have not heard anything about them timming my valves, do you thing it could be that? again, this shop is telling me that the car is doing this because it is a HX and the CPU does that and that it is normal for this car. Should I change shop? Thanks for your help.
Gerardo
Old Aug 22, 2002 | 04:39 AM
E-AT_me's Avatar
well, sorry, but this is the wrong forum.... hehee.. but we may be able to help..
HONDATA89
51
May 21, 2018 02:12 PM
zx92027xz
Aug 11, 2012 06:47 AM
johnk92
May 13, 2012 08:53 AM
pimpwagon
Nov 12, 2010 08:41 AM
integra3586
Oct 15, 2005 01:56 AM
