h22 sol running rich and hesitates
Old Jan 22, 2009 | 08:17 PM
umair's Avatar
Default h22 sol running rich and hesitates
i have a h22a del sol and i am running a virgin p28 ecu. the car runs a rich and under full throttle it feels like it hesitates a little bit. do you think it has to do with the car not being tuned??? i was thinking about getting my ecu chipped from profunction(basemap tune). do you think that will help the car run a little better?? the car has h/i/e, walbro fuel pump, clutch and flywheel.
Old Jan 22, 2009 | 08:20 PM
iwanttokillgod's Avatar
Default Re: h22 sol running rich and hesitates
uh i dont know maybe the right ecu or get the p28 chipped
Old Jan 22, 2009 | 08:43 PM
umair's Avatar
forgot to mention its an auto ecu.
Old Jan 22, 2009 | 10:55 PM
trustdestruction's Avatar
get the right ECU
Old Jan 23, 2009 | 08:23 AM
umair's Avatar
Old Jan 23, 2009 | 10:02 AM
F20B-CX's Avatar
Umm..your problem might be due to the fact that you're using an ECU that controlled a 1.6L on a car that now displaces 2.2L.... The auto part isn't helping, either. Send the ECU off to be chipped, and make sure it gets converted to manual, assuming your car has a manual transmission. Get a basemap on it, and use it to drive to your local dyno to get tuned. Until you do all of these things, your car will run like turds. Don't stop at the basemap either. It's called a "base" map for a reason.
Old Jan 23, 2009 | 10:14 AM
rpared01's Avatar
see if you can get your hands on the correct ecu for your motor, a p13 and chip that if you need to
ThumperDumper
Aug 29, 2013 08:33 AM
playback
Sep 6, 2012 07:16 AM
erikiksaz1
Engine Management and Tuning
Jun 11, 2010 02:39 PM
birwin12
Aug 3, 2007 10:21 PM
