h23a1 in to 94 civic cupe help
ok this is the deal i found a prelude(93) that is on its way to the junk yard.. the engine and tramy are good the body is done.. i can get the engine for free, i have to get new motor mounts i can use the h22 mounts for the 94 civic.. and i read about the shifter relocation no big deal now the only problem i have is on the wire harness do i need to do some modifications or its just a swap? and what cv axels i need.. i dont need to make crazy power my good old d15 has over 220k
off the top of my head : you should ok with the h22 mounts kit for your car. you will need to modify you harness to the motor. as far as axles go, well every one has their own setup. but i would recommend you take the motor, tranny, the engine harness, ecu, axles, shift cables, shifter.
that all i can think of right know. little help guys, if im missing anything lets list. also check out the faqs on here and in the prelude section. lots of info here and there.
hope this helps and if you do go though with the swap, welcome to the h family
stackz
Apr 16, 2004 02:17 PM
