Need help finding Secondary O2 Sensor for 98 GSR
Hi, guys I need help finding an affordable secondary/rear o2 sensor for a 98 GSR. I don't need anything fancy, but would prefer to get NTK/NGK. I would like to stay away from the OBX ones, as I've read some pretty bad things about them. Reason I ask for help is that after searching online for a while I cannot seem to find anything under $120. I'm hoping to spend around the $60-$70 range. Any help would be appreciated! Thanks.
I bought one a while back. The OE replacement part made by NGK/NTK is 24169 or 24172 (same thing). It is $60-70 and is a direct plug in. No splicing needed. I bought it at my local auto parts store but you can find it at Amazon.
www.rockauto.com has lots near 60-$70 Really fast shipping too... I would highly reccomend them. If you google for a discount you can usually get 5% off too.
i just looked at rock auto, they have one walker for $77 but there is no picture to verify it's the rear sensor. the next cheapest is the $115 bosch. please post links to these $60-70 rear o2s i would like to see this.
BOSCH Part # 15733 More Info {Oxygen Sensor - Universal Type - Downstream Sensor}
4 Wire; Planar; Check / Replace Interval: 100,000 Miles
$55.89
My understanding is that Upstream = Primary 02, Downstream = Secondary. Make sense to me at least...
The first one in the list is $44, but the Bosch is a brand name at least... There are many others also.
$55.89
NGK Oxygen Sensor
Pre-Catalyst 24169 $60.39
Post Catalyst 24546 $94.99
Both prices and parts found at Summit Racing
Bosch 13074
Ebay Auction Buy It Now at 43.60+8.00 Shipping=$51.60
http://cgi.ebay.com/ebaymotors/Bosch...QQcmdZViewItem
Bosch 13074
Cool Cool Island Breezes. BOY-EE
$55.89
$55.89
I would not recommend using a sensor w/o the OEM plug already on it. You would have to splice/solder the 4 wires from the harness on your old O2 sensor. With the tiny voltage fluctuations the ECU has to read from these sensors, I wouldn't want to risk having a bad connection making my A/F ratio different than what it should be.
Although, it's only the primary O2 that tells the ECU how to adjust the air/fuel ratio. I believe the secondary O2 is only there to make sure the catalytic converter is there and working correctly. And if it's just that, I don't understand why it's ALWAYS more expensive than the primary.
OP - are you sure you need to replace your secondary O2? Are you getting a CEL indicating that the secondary O2 is bad? If not, I wouldn't worry about it, because as I said, only the primary O2 affects your air/fuel ratio.
I was cheap, and wired up an O2 simulator to my dead reading secondary O2 sensor.
Snap-On OBD scanner shows everything back in spec. again.
what are the short and long term fuel trims doing when you drive on the scanner? is the short still idling warm at + or - 4? drive a little and see if your long term moves. if it's still close to zero you're golden.
are they only used for catalyst efficiency in our cars? i could have swore that i read the secondary is used for xx% changed in AF. i could totally be wrong, you ever test it?
TurboGS-R
Jul 10, 2006 04:45 PM
