Gaskets - OEM or Aftermarket
Old Jan 22, 2009 | 12:07 PM
harveyy's Avatar
Default Gaskets - OEM or Aftermarket
I have an 89 civic. I'm replacing the valve cover gasket and tube seals to fix oil in the spark plug tubes.
Is there much of a difference using Honda gaskets or is after market the same. Napa sells a Victor Reinz set.
Do you guys recommend putting some kind of sealant on the gasket as well?
Thanks.
Old Jan 22, 2009 | 12:16 PM
90_EX_Civic's Avatar
Default Re: Gaskets - OEM or Aftermarket
best is always oem. but if it's just the valve cover gasket and gromet then napa, autozone, advance, kragen, or o'relleys well do. just make sure you get some blue/black high temp RTV(think that's what it's called) silocone. comes in a small tube
Old Jan 22, 2009 | 12:17 PM
DTA-Zombie's Avatar
yeah he is thinking of rtv (silicon gasket maker basically)
gaskets like those you can use aftermarket - may not fit perfect but will work just fine
Old Jan 22, 2009 | 12:41 PM
fishinfool88's Avatar
I used the Fel-pro kit that includes all of that for 20 dollars at Autozone. Hasn't leaked since.
Old Jan 22, 2009 | 01:40 PM
dacrxguy's Avatar
it all depends on what you are doing if you are dd the car then you can get away with any auto store gaskets since its just the valve cover. If it were for something more important like the head or oil pan i would use oem but whatever rocks your boat
hondabond ftw
Old Jan 22, 2009 | 03:10 PM
xci_ed6's Avatar
hondabond is oldnews
Honda UltraFlange is where it's at. Same as Permatex Ultra Grey. Honda has switched over to the gray stuff, Nissan and Toyota too.
Old Jan 22, 2009 | 04:09 PM
dacrxguy's Avatar
so is Permatex Ultra Grey the same thing has the new Honda UltraFlange just wiht hondas name on it?
Old Jan 22, 2009 | 04:23 PM
crx_si-r's Avatar
i tend to like the beck/arnley gaskets, mainly because they have a lifetime warranty
Old Jan 22, 2009 | 08:16 PM
neogenesis2004's Avatar
I just rebuilt an entire HF motor for my DD crx with a gasket kit I got off ebay. Its running great and there are 0 leaks since first startup. I personally think its more in the prep and build than the gasket manufacturer.
Old Jan 22, 2009 | 08:21 PM
happyj9008's Avatar
when i got my H23, i tore down the head and used Fel-pro gaskets. They've lasted about 3 months so far, then i totalled my cb7 and i'm bound to say they will last alot longer when i swap the engine over to my new car.
OEM is best, but aftermarket is just as good in most cases.
-Jordan
Old Jan 23, 2009 | 08:17 AM
harveyy's Avatar
Thanks guys!!!
Old Jan 23, 2009 | 08:38 AM
xci_ed6's Avatar
AFAIK, Nissan is the same, Toyota is the same, the Honda stuff has the same texture, smell, and curing times.
Way easier to work with than HondaBond, it is almost the same color as aluminum so it doesn't show up if you put on a bit too much.
skate1968
10
Sep 2, 2010 04:34 AM
Rauch
May 21, 2010 11:08 PM
shortlid
Mar 10, 2008 03:38 AM
darkfx
Oct 8, 2005 09:51 AM
EnjoyTheRideDC2
Aug 26, 2005 03:41 AM
