Integra not getting fuel
Old Jan 22, 2009 | 09:20 AM
B-Rex's Avatar
Default Integra not getting fuel
I have a 91 teg, fuel pump turns on and stays on an there is no fuel getting to the fuel rail has anyone else had this problem or no a possible solution ?
Old Jan 22, 2009 | 10:25 AM
mouab18c1's Avatar
Default Re: Integra not getting fuel
check your main relay...
Old Jan 22, 2009 | 01:13 PM
B-Rex's Avatar
replaced it still nothing
Old Jan 22, 2009 | 01:49 PM
paton5g's Avatar
If the pump is on, I think the main relay is fine.
You have some kind of flow problem. Check your lines. How do you know it's not getting to the rail? Did you remove the hose?
Old Jan 22, 2009 | 02:21 PM
Civic92Turbo's Avatar
check your fuel filter/fuel pump filter, they get real clog on the old style systems, if not that then you may have to check your lines
Old Jan 22, 2009 | 02:35 PM
bakertime's Avatar
Yeah, replace your fuel filter. That's a good place to start.
Old Jan 22, 2009 | 05:23 PM
B-Rex's Avatar
i took of the feed line to the fuel filter and its still not coming out and my fuel lines are'nt leaking.
Old Jan 22, 2009 | 06:19 PM
jdm91ls's Avatar
check all fuel lines going back to the tank for kinks, also fuel pressure regulator??????
DevontElan
Feb 14, 2008 03:16 PM
blinger
Sep 1, 2007 10:35 PM
StraightCivic
Apr 24, 2006 03:58 AM
crnimacak
Apr 21, 2006 10:11 PM
shift6
Sep 7, 2004 09:39 PM
