Need help with AN fittings
Im looking to find a fitting that would make this work. im going from a -8 line to a -6 drainback into the block. Do they make a male -8 to female -6? if they dont i would need to get a male to male -8 to -6. i plan on changing the fitting at the end of the line to a straight fitting instead of the one that is pictured.
thanks for your help guys let me know
9893068 -6 FEMALE TO -8 MALE EXPANDER
http://www.anplumbing.com/shop/index...&dept=Aluminum
this is where i got them before. sometimes jegs/summit will have odd stuff like this, sometimes they wont
http://store.summitracing.com/partde...5&autoview=sku
its cheaper at anplumbing
i had -6mals on the bottom of my catch can, to -8 line and fwiw, that setup wasnt enough for my drainback and kept filling up my catch can.
went t1 style with 6 -10 no mo problems.
well see what happens this is that im workin with for now, the fitting is welded into the back of the block i dont have a problem dumping out the excess bs
Male -8An to Female -6An $ 9.45 each.
Shipping is $ 5 to NY
I guess you guys forgot about me LOL..
If you need them, let me know. We have over 20 in stock.
It takes a little more than that to clean up oil off of a race track, not to mention the danger you may cause to the next guy lined up behind you if you race the car, or oil that may find its way on your front tires.
sweet i will be contacting you in a bit when i can get my car, or maybe later still havent hit the sack yet and its 556 so idk yet. ill order from ya sometime!!
integra-modder
May 5, 2005 11:13 PM
