2500 rev limit b18b1 swap
Old Jan 21, 2009 | 08:59 PM
JDMbitches's Avatar
Icon6 2500 rev limit b18b1 swap
so just got my car running i am throwing a few codes. 7,14, 1 and it wont rev past 2500 rpm in or outta gear. my question is what could it be. it ran perfect in my 92 civic si. i used the stock 92 gsr harness. whats weird is sometimes it will rev past that point.also i think my distrbitor is bad or my ignition timing is off could this be it
Old Jan 21, 2009 | 09:02 PM
j_bizach's Avatar
Default Re: 2500 rev limit b18b1 swap
a) have you messed with or romoved the diizy or timing belt since the car ran right b) find out wat the codes ur throwing are for and then get back to us need more info
Old Jan 21, 2009 | 09:20 PM
JDMbitches's Avatar
no i havent remove the timing bet or dizzy but there is a line like this _- kinda like ascribe. this i why i thing the ignition timing might be off hence thats why it mont rev past 2500. its like its the rev limiter. according to haynes code 7 is tps i think it just needs to be calibrated code 14 is iAcv and code1 is02 sensor. ohh yea car is obd1 using a p75
Old Jan 21, 2009 | 09:28 PM
j_bizach's Avatar
Check ur tps that could be it but really when somethings wrongs it will almost always throw an o2 tps code if u know someone with a diagnostic compter get them to take a look at ur sensor outputs.
If u havnt messed with the timing the timing is fine UNLESS youve messed with it. SO if you think u messed with it check it. its not going to decide that suddenly it doent like the timing anymore and not run.
Old Jan 21, 2009 | 09:37 PM
JDMbitches's Avatar
yea im goin to check the tps as soon as i get a voltmeter the motr runs fine strats rite up cold, ang will marm up and run fine. idie is a little bouncey on the tach. what about the iacv could it be a wrongplug that i useg for it?
Old Jan 21, 2009 | 09:48 PM
j_bizach's Avatar
No it mite need to be cleanedid do that but when ur motors not running rite itll throw codes like an o2 tps, iacv, map because watever is making the car run shity is also messing with all these sensors.
Its like a flat tire now imagin ur steering and brakes have sensors. ALrite ur tire goes flat and now u cant steer and ur braking is hampered so ur computer say hey fix ur steering and brakes but thers nothing wrong with these things its the flat tire u fix the flat tire and no more codes.
This is why having a diagnostic computer comes in handy cause itll show ur sensor outputs which will allow u to better pin point wat the problem is.
Old Jan 22, 2009 | 08:45 AM
mpls's Avatar
its your dizzy trust me. put in a new dizzy and try it agian
Old Jan 22, 2009 | 07:13 PM
JDMbitches's Avatar
yea i get u on the flat tire thing i just cant affrod those over priced tools any. thats why i used the check light blinkin trick to get my codes. {could be a switchd plug alot of the plugs on my harness look the same any one no what wires go to the plug the goes on the iacv} would a iacv from a 91 b18a1? and as far *** my dizzy i thinking it might be the reason tho ive pretty much had evry thing tuned from wires to a coil pulgs etc before the b18b1 left my hatch back
thanks for input
Old Jan 22, 2009 | 07:50 PM
Sumslapper's Avatar
Year 3030
make sure your map sensor plug and tps sensor plug are not backwards! either plug can fit. I did this once before when i did a head swap and i couldnt rev past 2500.
Old Jan 22, 2009 | 08:50 PM
JDMbitches's Avatar
yea ill try that tmrw while im at work. if they where back words woulent i get a map code?
vtec8200
Nov 17, 2010 01:29 PM
Adi_King
Apr 16, 2010 08:33 PM
stevn
Nov 20, 2008 12:06 PM
phildeez
May 11, 2002 05:00 PM
