Aluminum Exhaust
Old Jan 21, 2009 | 08:46 PM
m R g S r's Avatar
Default Aluminum Exhaust
Let's see em! I plan on doing a 3.5" or 4" aluminum exhaust for my s2k. Would like to see some of your setups!
Old Jan 21, 2009 | 09:34 PM
k24em2's Avatar
Default Re: Aluminum Exhaust
I'm working on a 4" aluminum exhaust for a turbo LS1 FD3S. I'll snap some pics when its finished.
Old Jan 21, 2009 | 10:17 PM
Tony the Tiger's Avatar
Probably a better thread for the welding/fabrication forum instead
Old Jan 22, 2009 | 05:05 AM
m R g S r's Avatar
I didn't know which to post it in. But I figured the only guys running aluminum exhaust would be turbo guys because of the large piping looking for weight savings.
Old Jan 22, 2009 | 05:09 AM
Tjabo's Avatar
Not sure if this is really on topic for the thread, but it fits with the title:
What have people noticed related to in-car sound level with aluminum exhaust tube compared to steel? I'm thinking I might want to try some this spring, but if it's known to make the car super noisy inside, then I probably won't mess with it.
Thanks in advance!
Old Jan 22, 2009 | 05:26 AM
Turbo-charged's Avatar
just a few ive done
Old Jan 22, 2009 | 05:34 AM
Tjabo's Avatar
Originally Posted by Turbo-charged
just a few ive done
Any thoughts on in-car sound level compared to steel tubing? I understand those suckers in the pics are not quiet street systems, but still you may have some observations?
Thanks!
Old Jan 22, 2009 | 07:09 AM
its hard to say. i think if your at the point where you use your car on the street and what not--- where you are concerned about sound, the aluminum exhaust probably isnt worth while at that point.
it seems when you go to a 3.5-4 inch exhaust...its actually louder over all than open downpipe/header. thats when you use a "race muffler" anyways
Old Jan 22, 2009 | 08:00 AM
redboost10's Avatar
i routed my 4" like stock exhaust is.
Old Jan 22, 2009 | 09:37 AM
Tjabo's Avatar
Okay, thanks!
I'm planning on only running 3", into a pretty good sized oval Magnaflow, so I may give it a try just to find out how well it works. I'm thinking an eBay intercooler pipe kit will give me most of the bends and whatnot that I need, although not much cheaper than Global-Tech, so I'll probably just go that way. Everyone seems happy enough with their mandrel bends and overall quality I guess. . .
Old Jan 22, 2009 | 09:38 AM
josh green's Avatar
Are people also running aluminum down pipes also? That seems like a lot of heat right off the turbo for aluminum.
Old Jan 22, 2009 | 12:15 PM
m R g S r's Avatar
It won't melt the downpipe unless your tune is really really f'ed. And at that point I think you will have some engine problems too
Old Jan 22, 2009 | 12:50 PM
dont use that ebay tubing, its generally thinner than 16g and i have gotten calls about that cracking/blowing holes in it.
i made an aluminum downpipe for a K series car that went 9.3 at over 160....it only lasted 2 pass's before it blasted a hole right through it. the downpipe had to make a really sharp turn directly off the turbo and i think that was the problem. either way, i just stick with stainless downpipes now
Old Jan 22, 2009 | 12:53 PM
905_Legend's Avatar
I've seen an aluminum down pipe sag after a few dyno runs and track day
Old Jan 22, 2009 | 01:06 PM
Tjabo's Avatar
Okay, that solves it, thanks!
I guess I'll get my stuff from global-tech, and maybe if I'm lucky welding it will be easier than it was on that eBay tubing too. I hope!
Thanks!
Old Jan 22, 2009 | 01:24 PM
boost fed ls's Avatar
just a few ive done
Sorry for the thread jack but is that a resonator on the end of some of those exhausts? I am looking for some kind of inline muffler or resonator i can place under the car so i dont have to run the exhaust all the way back of the car.
Old Jan 22, 2009 | 01:45 PM
905_Legend's Avatar
its a vibrant race "muffler"
Old Jan 22, 2009 | 02:52 PM
redboost10's Avatar
just weld the ss muffler to the ss downpipe, and that will eliminate an extra vband at the rear of the car when running al exhaust
Tyler H
Welding / Fabrication
41
Jun 13, 2005 11:17 AM
gsr0102
Mar 26, 2004 03:52 PM
Boostless-Lude
Dec 3, 2003 09:25 PM
PrecisionH23a
Jul 27, 2002 11:13 AM
Cow
Dec 23, 2001 04:59 AM
