Aluminum Exhaust
Re: Aluminum Exhaust
I didn't know which to post it in. But I figured the only guys running aluminum exhaust would be turbo guys because of the large piping looking for weight savings.
Not sure if this is really on topic for the thread, but it fits with the title:
What have people noticed related to in-car sound level with aluminum exhaust tube compared to steel? I'm thinking I might want to try some this spring, but if it's known to make the car super noisy inside, then I probably won't mess with it.
Thanks in advance!
Thanks in advance!
its hard to say. i think if your at the point where you use your car on the street and what not--- where you are concerned about sound, the aluminum exhaust probably isnt worth while at that point.
it seems when you go to a 3.5-4 inch exhaust...its actually louder over all than open downpipe/header. thats when you use a "race muffler" anyways
I'm planning on only running 3", into a pretty good sized oval Magnaflow, so I may give it a try just to find out how well it works. I'm thinking an eBay intercooler pipe kit will give me most of the bends and whatnot that I need, although not much cheaper than Global-Tech, so I'll probably just go that way. Everyone seems happy enough with their mandrel bends and overall quality I guess. . .
It won't melt the downpipe unless your tune is really really f'ed. And at that point I think you will have some engine problems too
dont use that ebay tubing, its generally thinner than 16g and i have gotten calls about that cracking/blowing holes in it.
i made an aluminum downpipe for a K series car that went 9.3 at over 160....it only lasted 2 pass's before it blasted a hole right through it. the downpipe had to make a really sharp turn directly off the turbo and i think that was the problem. either way, i just stick with stainless downpipes now
I guess I'll get my stuff from global-tech, and maybe if I'm lucky welding it will be easier than it was on that eBay tubing too. I hope!
Thanks!
