b16 valve stem seal removal
Old Jan 21, 2009 | 07:27 PM
thedudefromjerz's Avatar
Default b16 valve stem seal removal
Im have trouble removing the stem seals on my b16. They wont budge. Im grabbing them with pliers and pulling up but no luck. I need some advice from somebody thats done this. Thanks.
Old Jan 21, 2009 | 08:42 PM
jturbo8316's Avatar
Default Re: b16 valve stem seal removal
you have to use a punch and hammer to get them out. the punch has to be a little smaller than the stem seal so that it'll go threw and wont F up the head.
Old Jan 21, 2009 | 10:30 PM
89s1's Avatar
wat?
OP: twist and pull dude, are they all stuck? or is it just a few?
Old Jan 21, 2009 | 10:47 PM
ZC DOHC CRX's Avatar
when i did my valve stem seals on my gsr head mine were all stuck. had to use a pick and hammer to cut them off not the best way but it works. and i tried every tool possible fisrt.
Old Jan 22, 2009 | 01:14 AM
D16SiHatch's Avatar
you can actually get a valve stem seal puller tool. but if that doesnt work and they're really stuck on there you may have to try something more drastic like what was explained above ^
Old Jan 22, 2009 | 06:55 AM
I forgot to mention the head is still on the car. The seals are rotating but i just cant pull them off the guides. Im gonna try and make my own puller.
Old Jan 22, 2009 | 09:57 AM
Black4thgenEF's Avatar
I just used pliers and persistance - they eventually all came off
Old Jan 22, 2009 | 02:00 PM
i used the tool shown above as well as making my own tools. i just said screw it they are getting cut off. just try not to screw up the gudies. good luck
Old Jan 22, 2009 | 08:18 PM
neogenesis2004's Avatar
If they will spin then they are not seized. I think you need to stop being a ***** and pull harder. You aren't going to break anything other than a seal you plan on replacing anyway. Get a set of locking pliers on them if you can't get a good enough grip with regular ones.
young geezer
May 19, 2009 04:41 PM
RACEPAK
11
Dec 11, 2005 03:03 PM
MUGEN_B16CIVIC
Jan 13, 2004 01:23 PM
jdmlsvtecrx
Sep 20, 2003 05:02 PM
Space Boy
May 30, 2002 12:46 AM
