99 gsr front and rear seats into ek hatch?
Old Jan 21, 2009 | 07:12 PM
kasperxtcy's Avatar
Default 99 gsr front and rear seats into ek hatch?
hi guys, i am planning to pick up a set of 99 gsr seats front and rear... i have been searching... there are ppl saying that the rears will fit into an ek hatch and other say no... so i am here now trying to figure that out for myself. i know the front i have to swap out the inner rails to make all 4 bolts line up. but how about the back? ppl say i have to use the 4dr bottom and use the 2dr top portion... so how about it guys i need some input b4 i pick up... oh yea i found this tread about doing a back panel change over on itr seats into an ek... can i use the same thing on the the gsr seats?
here the lick: https://honda-tech.com/forums/showth...+jdm+rear+seat
Old Jan 21, 2009 | 11:01 PM
kasperxtcy's Avatar
Default Re: 99 gsr front and rear seats into ek hatch?
bump...
Old Jan 22, 2009 | 01:52 AM
Dub9.Juice's Avatar
it will fit if not you mid have to do a little adjustments but usually it fits in their and u aint gotta worry about the person in the back seeking through as long as u got the cargo cover
Old Jan 22, 2009 | 01:54 AM
Dub9.Juice's Avatar
Fob i am ^^ lmao
Old Jan 22, 2009 | 02:25 AM
sp00ledbseries's Avatar
idk if the front seat rails will bolt in or not. but the back should fit
Old Jan 22, 2009 | 05:00 AM
tercel95's Avatar
I've been trying to accumulate this information for a little while now but people come on here ask these questions and then don't ever post how it turned out. All the info is there for EG's but not EK's. BTW you will have to swap the inner rail on the fronts but that is easy...
Old Jan 22, 2009 | 10:25 AM
ek4_b16a's Avatar
okay, the rear seats won't fit. only the top back piece will fit, but the bottoms won't. ^^what they said is wrong. i've bought gsr rear seats and thought it'd fit, but they have an almost two inch gap on each side. fronts will work, just swap the rails from your stock seats onto them. gl
and yes, to get the rear seats to work, you will need the bottom piece from the four door
Old Jan 22, 2009 | 05:34 PM
kasperxtcy's Avatar
okay that sounds right now. but is there anyone here with pictures of the gsr seats (front and rear) in an ek hatch? i have been looking but nothing. i've seen the leather but i never seen the cloth seats... if anyone here has pictures of gsr cloth seat in an ek i mean the rear seats also not just the fronts. send them my way...
Old Jan 22, 2009 | 07:58 PM
nextproject97's Avatar
I have an ek hatch with 99 front gsr seats and you have to switch both seat rails to make the holes line up and the seat slide work properly the gsr slides are different than the stock eks so switch both rails only takes a few minutes as far as the back seats I am still wondering so this is a good post for me to keep an eye on as I want to put leather in the back also
Old Jan 22, 2009 | 08:06 PM
lee0149's Avatar
wow surprise not a lot of people have things to say about this. will the front would fit okay one bolt off, not a big deal but if you want to switch to make all fours go ahead thats even better. NOw the back is kind of miss up. it will fit fine but a lot of gaps and ****. my bros ek have them i personally dont like how it looks and feels. its not right for the car. i've seen si cloths seats in a ek now thats the ****. look and fit good. ill post up pixs if you want when my bro comes home tomorrow.
Old Jan 23, 2009 | 11:11 PM
kasperxtcy's Avatar
alright if u can get some pictures of the si rear seats in an ek hatch send then my way... i want to see them for myself. cause i know someone down here who wants to get rid of their si interior.
Old Jan 23, 2009 | 11:36 PM
92hatch!'s Avatar
front and back fit perfect in my eg hatch
Old Jan 24, 2009 | 07:01 AM
Deetz's Avatar
Crazy Honda Guy
I have 98 GSr seats in my 96 EK. Three of the four bolts fit perfect. For the rear bolt that doesn't fit, you can mod the back of the gsr rail by cutting the very end off, and use a bolt with a larger washer....or just swapon the stock EK rail onto the one side as mentioned earlier.
Here's a shot of the fronts in my hatch
Old Jan 24, 2009 | 11:07 AM
IIXtremeHansen's Avatar
the 4dr integra rear bottum piece is what you need to make it fit in your EK hatch.
FRKWOO
Jan 10, 2009 07:30 AM
JDMcivicSiEG6
Dec 8, 2008 05:28 PM
civic4nick
Apr 14, 2008 06:09 PM
Freshsho
Jun 11, 2005 02:00 PM
