Can I put rear door handles on forunt door
Old Jan 21, 2009 | 06:36 PM
djrico724's Avatar
Default Can I put rear door handles on forunt door
Dose any body know if i can put rear door handels on my front doors of my 1995 civic 4Door.I have done this on my 91 CRx
Old Jan 21, 2009 | 06:38 PM
djrico724's Avatar
Default Can I put rear door handles on front doors
Old Jan 21, 2009 | 06:48 PM
iwanttokillgod's Avatar
Default Re: Can I put rear door handles on front doors
i have seen 4 door rear door handles used on front doors for the coupe or hatch
Old Jan 21, 2009 | 06:59 PM
arrocha87's Avatar
Default Re: Can I put rear door handles on forunt door
howd u do that in a crx if its only 2 doors? and do u mean inside or out? cause outside obviously has the key cylinders.. i think maybe u can do the inside tho...
Old Jan 21, 2009 | 08:04 PM
ES3's Avatar
ES3
if uv been talking about the outer door handles, yes you can use the rear door handles for the front but the problem is, there's no keyhole on the rear door handles.
Old Jan 21, 2009 | 09:49 PM
teamworxek9's Avatar
Yes, every civic can use the rear door handles from a 4dr on the front. I have it done on my ek. Just hook up a power lock actuator and look mom no key holes.
Old Feb 8, 2009 | 08:22 PM
djrico724's Avatar
Thanks !!!!!!!!!!!!!!!
Old Feb 8, 2009 | 10:14 PM
Mrmatt3465's Avatar
lawlz.
-"Mom I got a swap in my car!"
-"YOU WASTED $1500 ON YOUR CAR TO GO FASTER?!"
-".......yes ._."
Haha. If not I think you can just take the little lever off the key cylinder. Same thing. Just make a useless key hole! =P
Old Feb 8, 2009 | 10:37 PM
Haha. If not I think you can just take the little lever off the key cylinder. Same thing. Just make a useless key hole! =P[/QUOTE]
Your missing the whole point maybe someone with keyless entry doesnt want a keyhole. One less way to allow enterance to your car.
Old Feb 9, 2009 | 06:31 AM
ej1bmx's Avatar
And will look cleaner.
kkelson25
Sep 6, 2017 12:32 PM
shortlid
Mar 26, 2007 06:46 PM
ImportHatch
Jun 24, 2003 04:24 PM
RacerBoy
13
Mar 14, 2003 09:33 AM
