200hp out of a n/a gsr
ive searched around and some have said it cant be done without new internals.... i already plan on a cai, tri y header,, test pipe 2.5 exhaust all the way back,sk2 intake mani,some type of cams, s300 or neptune. i dont want to crack the motor open being its pretty mint with only 85k on it. so what cams and other things will be needed... or is it a lost cause?
If you dont crack open the block you wont be able to get high compression pistons so your cam choices are going to be limited. Looking at the setup you plan and a ITR setup, I dont see much differance besides the pistons and ITR's dont even come close to 200WHP
+1 with just bolt ons i'd see you doing something in the 170+ whp range. with a really good tune, and the right gas, maybe see 180 whp(190-200 on 110 octane maybe). now if you're looking for 200 hp at the flywheel, then it's not that hard.
Yea skunk 2 stage 2's would be nice if they didn't require high compression. Your car will run like crap with stock pistons and those cams. Because you don't want to crack open the block, you are pretty much limited to ITR/CTR cams or some other cams with a not so agressive profile.
a jdm itr motor normally puts down 170s and 180 with a good exhaust. they have 6cc dome pistons, better cams, better intake and a better exhaust. if you don't want to crack into the motor buy a small turbo kit. you will quickly hit 200whp
i didnt know people couldn't run skunk2 stage 2's with stock internals.... by valvetrain i assume u mean upgraded springs and retainers.... and im not against boost but prefer the reliability of n/a being its a simple daily driver not a track car...
i've got skunk2 stage1 tuner series cams, adjustable gears, proseries valve train, edlebrock vic-x intakemani, with some good exhaust and an s200. suppose to get it dyno'd when i get back, i'm hoping to push 175hp. But 200hp n/a without bumping up the pistons is a long shot.
will post dyno results when i get them.
there are other ways to bump compression such as a thinner headgasket. You can use an OEM hg and removing 1 layer (same as the mugen). Also, milling the head will bump you up a notch. These are just ideas due to the fact that you don't want to go inside the block.
Also, p30 pistons will yield higher compression than ITR's in a gsr motor. Keep that in mind just incase you decide to go internal.
if you're really after power boost is the cheapest way to do it. personally, i'm driving a jdm itr motor and happy as a clam. if you are happy with a balanced car that gets great mpg your build might be an idea. if you're after power leave the motor stock and buy turbo parts.
sm010996
Oct 13, 2017 10:20 PM
Db1 Supreme
Jan 26, 2006 12:17 AM
