obdo to obd1 dizzy wire conversion HELP!!!
Old Jan 21, 2009 | 05:01 PM
SLURS's Avatar
Icon3 obdo to obd1 dizzy wire conversion HELP!!!
-what up people I need Help!!! I have a d16z6 and my wiring harness is obd0 and I have a dizzy thats obd1 I want to convert it to obd0 can anyone help me with any diagrams, or if you are a tech can you help!! im in Long Beach,Ca. Or if you have any suggestion I will takem!
-I was also looking online for wire conversions and found rywire.com but they do not sell the conversion by itself if you know any other sites where i can find them that would help
Old Jan 21, 2009 | 05:14 PM
D16SiHatch's Avatar
Default Re: obdo to obd1 dizzy wire conversion HELP!!!
ebay:
http://cgi.ebay.com/ebaymotors/HONDA...20111006r36061
or you could make one yourself
http://www.d-series.org/forums/showthread.php?t=57665
Old Jan 21, 2009 | 05:31 PM
SLURS's Avatar
hell yea thanks bro!!
intense4thgen's Avatar
match the wires color for color just watch out for the white wires one is a sheilded and one is not and your done
Old Jan 21, 2009 | 07:29 PM
almostjdmeg's Avatar
Use this, i used it and it worked for me.
http://boomslang.us/obd0_1.pdf
Old Jan 21, 2009 | 11:32 PM
SLURS's Avatar
**** yea thanks!
Old Jan 22, 2009 | 08:03 AM
jhammond_82's Avatar
Reject Papi
good info
Old Jan 23, 2009 | 05:18 AM
lilsicsoul's Avatar
Did I get this right?
U can take a obd1 dizzy and run it on a obd0 harness just by cutting the plugs off the obd0 dizzy and adding them to the obd1 dizzy....
So obd1 and obd0 dizzys internals are the same?
Old Jan 23, 2009 | 07:11 AM
correct me if i/m wrong but the obd1 and obd0 distributors are different on the inside for sure. And yes, just cutting the plugs and put them on the distributor or you can make a jumper harness
Old Jan 23, 2009 | 07:46 AM
jlicrx's Avatar
you cannot run an OBD1 distributor with OBD0 ECU - the internals are not the same - if you are running an OBD1 ECU with OBD0 to OBD1 ECU jumper, you use the OBD0 engine harness and swap the OBD1 distributor plugs onto the OBD0 harness and run the OBD1 distributor
Old Jan 23, 2009 | 08:53 AM
lilsicsoul's Avatar
Ok I'm losT are u gonna use a jumper harnes to make ur car obd1...
Or you just wanna use the obd1 dizzy wit the obd0 harness
Old Jan 23, 2009 | 09:17 AM
lilsicsoul's Avatar
Sorry 4 thread jackiing...
I'm gonna make my own thread..lol
91lsteg
26
Sep 1, 2012 07:41 AM
thundernutz
Nov 4, 2009 06:28 AM
burnt_rice
Jan 5, 2006 08:36 AM
650EF9HATCH
Feb 1, 2005 11:21 AM
91LSVTEC HB
10
Aug 23, 2004 03:03 PM
