Where does Honda ignition get its signal from?
Old Aug 6, 2002 | 09:23 PM
Dokta's Avatar
Default Where does Honda ignition get its signal from?
When I installed my MSD box into my 93 civic Si I ran a wire from under my distributor cap to the ignition control module, from there to the blaster coil, and from there to distributor cap to be sent to each individual spark plug. Where does that original wire that I ran from under the distributor cap to the ignition control module come from? I wanted to know what gave my MSD box a signal.
Old Aug 6, 2002 | 09:27 PM
sgT's Avatar
sgT
Default Re: Where does Honda ignition get its signal from? (Dokta)
the wire you ran comes from the ignitor which gets its signal from the ecu.
Old Aug 7, 2002 | 02:51 AM
kinesistech's Avatar
You got the trigger wire for the ignition. Its the wire that would be connected to points. Its the switch for the coil. It says "now".
MattMcCrossfit
Jun 8, 2016 09:26 AM
MalcolmV8
May 13, 2012 08:35 AM
94gsr
Jun 1, 2004 12:55 PM
integra-modder
May 16, 2004 12:07 PM
WeaponR
Apr 4, 2004 09:44 PM
