LCA problem?
i just installed blox control arms and asr subframe but i wasnt able to get the right side on due to a stripped bolt. and also the tie rod i believe on the left side ripped(the rubber piece), how much do the tie rods go for usually? and im not even sure if thats what you call it? It connects to the lca and then to the sway bar. would i be better off going to the dealer? i just dont want to pay a lot of money where as if i can find it online for cheaper.
You're referring to the sway bar end links. Most likely with those POS control arms, you'll have to use POS adjustable end links to get it all bolted up.
Tuner Eddy
13
Dec 22, 2007 06:01 AM
SickIntegraWon
Nov 15, 2007 08:41 PM
rawkus
Sep 30, 2007 12:57 PM
