Help on My first swap it's a B18c1
Old Jan 21, 2009 | 02:06 PM
milano_vtec's Avatar
Default Help on My first swap it's a B18c1
I have a B18c1 Head what could i do with it what block combo would work and trans.So Far I have Skunk2 Tuner Cam gears Oem Gsr Cams but I wanna change them for some Type R Cams. I also want to add some Type R Valve springs and Retainers.. I want it to be a reliable daily driver for weekend racing. ... I'm looking for 170-180 Hp N/A.. Any Info Would Help... THANKZ
Old Jan 21, 2009 | 03:14 PM
ekb16's Avatar
Default Re: Help on My first swap it's a B18c1
u can try a b20vtec or lsvtec setup wit a b20 block or b18a/b and the gsr head or find urself a gsr block and just keep it a stock gsr setup...any b series trans will bolt up to any b series block
Old Jan 21, 2009 | 03:29 PM
redracerk20's Avatar
get a B20, there torquie as ****
Old Jan 22, 2009 | 05:16 AM
Thanks... What are the Hp difference in b20 vtec,ls/vtec and stock gsr ?
Old Jan 22, 2009 | 08:54 AM
im not sure, cuz im not into the B series that much, but i know that the B20 has the most torque.....and its personally my favorite
Old Jan 22, 2009 | 08:57 AM
mpls's Avatar
do a poorman r
Old Jan 22, 2009 | 09:57 AM
Ser1N's Avatar
Just 1 downside to b20s, the cylinder walls are weaker so you dont wanna rev as high .
Old Jan 22, 2009 | 10:08 AM
Matt55's Avatar
b20 a's depending on what year are from 140-160 hp and its dohc but not vtec but it has a programmed fuel injection and gsr is b18c1 wit 170 hp idk about the ls vtec since its a hybrid
14psi
May 14, 2013 09:08 AM
notburton06
Sep 10, 2008 09:08 PM
integraboi2626
Aug 29, 2006 06:55 PM
dxhatch1993
17
Sep 15, 2004 03:11 PM
bsemeyn
Sep 30, 2003 06:15 AM
