Base timing?
Old Jan 21, 2009 | 12:55 PM
EX-T's Avatar
Default Base timing?
Is base timing when the crank is at TDC with the mark on the crank at the top and the cam is at 0* with the mark on the cam gear at the top?
Old Jan 21, 2009 | 01:40 PM
EX-T's Avatar
Default Re: Base timing?
Is base timing also known as mechanical timing?
Old Jan 21, 2009 | 03:26 PM
lcsej1's Avatar
i believe its the same as ignition timing. When #1 piston is at TDC
Old Jan 21, 2009 | 04:16 PM
nub's Avatar
nub
Base timing and mechanical timing are not the same. Mechanical timing is what you described in you first post, cam and crank alighnment. Base timing is what you adjust with the distributor and timing light ie: 12 degrees before top dead. You also have timing advance that can be centifugal, vacuum or computor controlled. These are added to the base timing to give you total timing or total advance timing.
chengrazng
Aug 23, 2007 11:03 AM
smkngsr
Dec 30, 2003 08:31 PM
Norcalstoppy
Nov 12, 2002 11:32 AM
