Northern California North of Fresno
type r swap
Old Jan 21, 2009 | 12:47 PM
eskerley's Avatar
Default type r swap
I have a 2000/98 type r in my 92 eg. I have to get it refereed in cali and when i took it their they gave me a long a long list of things i have to do to legalize it. I have to run the type r ecu and i cant use a jumper harness because i have to have the obd2 data link connector inside the car also. I believe the only way for me to do this is to change the engine harness to obd2, ecu harness, and the harness on the passenger side (I think thats where the connector is but not sure)
I know its not going to be the easiest thing to do, but what problems am i going to run into doing this? Has anyone done this that can help me out? Are their parts in my civic that arent going to work after i do this?
Please any help would be awesome, i have to do this by the end of february, and their is more to
Old Jan 21, 2009 | 12:54 PM
jdm.norcal's Avatar
Default Re: type r swap
good luck with that o.0
Old Jan 21, 2009 | 02:00 PM
defnu's Avatar
if you need it done in a timely matter, having a shop do it might be the easiest thing. if you're in the stockton area, i suggest parris engines (former ssr). give derrick a call and let him know what you'll need. he might be able to give you a quote over the phone.
Old Jan 21, 2009 | 08:23 PM
eskerley's Avatar
awesome, i will definitely check that out.
EG*RYDER
Sep 14, 2011 06:56 AM
eskerley
33
Jan 29, 2009 12:31 PM
1BADEGDC2
10
Jun 26, 2007 09:45 AM
ugen
Nov 27, 2005 10:30 AM
