E-brake light on when Accelerating
Old Aug 6, 2002 | 09:04 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default E-brake light on when Accelerating
Whenever i accelerate briskly my ebrake "BRAKE" light goes on. Kinda of annoying and id like to fix it. I just had my 30k service done, and im thinking when they tightened the cable they did it TOO much. Should i just loosen the cable or could it be something else?
yellow blur's Avatar
Default Re: E-brake light on when Accelerating (Rguy)
Check your brake fluid level.
Old Aug 6, 2002 | 09:05 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: E-brake light on when Accelerating (yellow blur)
Really? for an E-brake light?
Old Aug 6, 2002 | 09:33 PM
MackSpeed-616's Avatar
yes the brake light doubles as a reservoir level indicator
Old Aug 6, 2002 | 09:41 PM
GZR4DR's Avatar
Default Re: E-brake light on when Accelerating (BustaNutt-616)
Another option to check is the tension on your ebrake cable. Perhaps if its tight, under acceleration it could trigger it. Most likely brake fluid level as they said. You learn something everyday. Thx for the info on that one.
Old Aug 6, 2002 | 10:41 PM
Ross's Avatar
25 Year Member
Community Builder
Active Streak: 30 Days
Default Re: E-brake light on when Accelerating (GZR4DR)
That's funny, this has been happening to me a lot too.
It's not the brake fluid level, and the cap to the resevior is on tight. What else could it be?
Old Aug 6, 2002 | 10:43 PM
Chris's Avatar
Old Aug 7, 2002 | 12:43 AM
ingrate's Avatar
25 Year Member
Default Re: E-brake light on when Accelerating (Chris)
i had the same problem a while ago.. turned out my neuspeed front stb was crushing the wires that lead up to the sensor in the brake fluid reservoir cap. if you have a neuspeed strut bar you may want to check that out
Old Aug 7, 2002 | 12:47 AM
Jmm0056's Avatar
Default Re: E-brake light on when Accelerating (In7egrity)
I had the problem right after I got my car, it was the brake fluid level
Old Aug 7, 2002 | 02:59 AM
Zeus's Avatar
...Mine is doing the same... Fluid seems to be fine... since there are no leaks and pressure is fine, I haven't taken the time to investigate farther...
Zeus- who should find out what's wrong before it bites him in the ***...
Old Aug 7, 2002 | 03:35 AM
Stumpy's Avatar
Default Re: E-brake light on when Accelerating (Zeus)
The same thing happened on my dad's car (it was a toyota, though) he took it to a dealer and they said it was a wire. *shrugs*
Old Aug 7, 2002 | 05:07 AM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: E-brake light on when Accelerating (Stumpy)
I love when people call the parking brake the E-brake!! pull that thing when you are having an "emergency" and see that situation go from bad to worse!!
As for the problem- I agree with the masses; top off your fluid. I actually had this happen and I had to go a little over max to get it to stop.
later
matt
Old Aug 7, 2002 | 05:12 AM
ZygSpeed's Avatar
Default Re: E-brake light on when Accelerating (champITR)
Ditto
Must be why people started putting "socks" on the reservoirs!
1cool87Civic
Classic Hondas
Feb 13, 2012 09:11 PM
shocker911
Oct 7, 2010 04:24 PM
infantry
Apr 26, 2004 08:59 PM
Thrillhouse
Oct 10, 2002 12:15 PM
Proper
Jul 26, 2002 05:57 AM
