quick question about MAP sensor
Old Aug 6, 2002 | 08:39 PM
poison's Avatar
Default quick question about MAP sensor
Hey, I'll be getting a JDM h22 from HMO this friday, and I was told by several people that the JDM h22's MAP sensor is on the firewall instead of the intake manifold. And i"ll probably be NOT receiving the MAP sensor from HMO since it's not on the actual engine, thus me having to wait a while,
question-- i have a 93 civic ex (ej1) that i am swapping the h22 into, I can use the same denso MAP sensor for the h22 except it being tied up to the P13 ecu and would run right, correct??
also
question 2 -- my friend who is buying my motor has a 92 CX hatch and is buying my stock d16z6, if i take my MAP sensor for the H22 (if question #1 works), then he can use HIS stock MAP sensor on the D16 correct???
TIA
[Modified by poison, 10:44 PM 8/6/2002]
Old Aug 6, 2002 | 09:30 PM
sgT's Avatar
sgT
Default Re: quick question about MAP sensor (poison)
Any honda map sensor will work.
Old Aug 6, 2002 | 10:52 PM
poison's Avatar
Default Re: quick question about MAP sensor (sgT)
coo coo, thanks man
that isn't a real pic in ur tach revving that high is it?
i was thinking the MAP sensor would work in any car because i looked at hondaautomotiveparts.com and they are the same part number.
thanks
tensaiwung
Apr 28, 2011 05:38 AM
jdmboostedhatch
Jan 22, 2009 11:50 AM
powerdbygarrett
Oct 2, 2007 08:28 AM
spoink
Dec 7, 2005 10:26 AM
