clutch kit for turbo
hi i was wondering..what clutch kit would you guys recommend for a d16z6 turbo and i plan to go stage 2..
1)competition stage 2
2)spec stage 2
3)exedy stage 2-plus
2)spec stage 2
This isn't Gran Toursimo...there is no "stage 2" turbo kit. You need to set an approximate power goal and determine your clutch choice based on that. Since you're running a stock D series, you're limited to ~220-240whp which means you probably won't exceed 200wtq. The Exedy stage 2 is a decent clutch. I ran that on my stock block GSR for 2 years at 315whp 216wtq and it held just fine. I ran it at the track several times...even a few with slicks. I would recommend that clutch for it's streetability factor...i have no experience with the others...
**Moved to Forced Induction...you'll get better answers here**
if you plan on running it alot and more importantly preloading it, an organic will not hold as long as a ceramic. just food for thought.
Last edited by boostedcivicsir; Jan 21, 2009 at 01:13 PM. Reason: spelling own2 me.
negusjuda
27
Feb 11, 2011 03:51 AM
