detonation ?
Old Aug 6, 2002 | 08:32 PM
wannab20hatch's Avatar
Default detonation ?
im looking into doing a b20 vtec all motor setup. where can i buy crv aftermarket
pistons? heres the setup im thinking so far.
b20z block
pr3 head
12.5:1 cr
crane 478 lift cams
itr valvetrain(higher rev limits)
hondata and all new high flow fuel setup
would i have to worry about detonation problems?
i wanna go all motor no turbo or sc
thanx for all the help and info.
Old Aug 6, 2002 | 11:11 PM
jdmDXrex's Avatar
Default Re: detonation ? (iwannahybrid88)
with that compression you will most likely have to worry about detonation. my friend has a crvtec bored .50 over with 12.5 cr JE pistons b16 ported head with ctr cams in his 96 hatch. he ran 12.8@~106 but his timing was backed down to 12 with 92 octane gas. and that was after he richened up his mixture with the Apexi vafc
Old Aug 6, 2002 | 11:21 PM
Kamin's Avatar
i would upgrade farther than jut the ITR valvetrain.
and yes, your gonna need to worry about detonation.
unless your running race gas.
Old Aug 7, 2002 | 09:21 AM
Kataku2K3's Avatar
Default Re: detonation ? (KAMiN)
Mike, he was running 19 degrees of timing on 104 octane on the 12.8@106 run!!!!
Old Aug 7, 2002 | 10:53 AM
IlikeTODA's Avatar
You will have to worry about detonation unless you have a good knock sensor or run race gas all the time.
J&S Safeguard comes highly recommended from several big names in the automotive industry. In fact I am about to purchase one myself. There is a group buy going on right now for them for $475 which is down from the retail of $545.
You can check out there page to read up more about it. JandSsafeguard.com
Thanks, J
Old Aug 16, 2002 | 07:03 PM
Default Re: detonation ? (IlikeTODA)
thanks alot for all the help and information guys. but i read a few other posts and i think im just gonna go with around 11:1 cr and just do alot of head work and leave it at that.
Old Aug 16, 2002 | 10:44 PM
Quick 200k Mile Motor's Avatar
Default Re: detonation ? (wannab20hatch)
11.0:1 with at least 91 octane.
That way you dont have to run retardly slow.
THEhomelessONE
10
Apr 20, 2022 12:23 PM
LSVTEC ReX
13
Aug 21, 2006 03:49 AM
j spec
11
Jul 26, 2006 01:36 PM
92bubblesi
Jun 20, 2004 08:30 PM
Gong Show
Aug 8, 2001 12:21 PM
