help...
I just got into an accident with the curb... it just seems my car likes hitting curbs.. don't ask why i hit it..heh neways i hit kinda straight on. The car runs fine right now. But when i did hit it red fluid came down a little but then stopped and didn't do it nemore. i think it was the transmission fluid. neways the radiator seems to be pushed back or my frame pushed up. The only thing im really worried about is whenever i put it into reverse. the whole front end of my car goes crazy and shakes violently until i press on the gas pedal. it gets worst wheneveri slow down in reverse. but when i switch it to drive it stops shaking and works fine. I just wanna know if this car is worth keeping. Cause i was planning to do an engine swap and tranny swap as well.. neways my car is an automatic and is a 94 accord ... i'll appreciate it if u can help!
i guess it is the rear motor mount.. i did a search heh well neways if i save up for the swap.. i can change the rear motor mount whenever i change the engine right?!
yes, but swap soon, because, what happened to me: if you leave that rear motor mount in to long, eventualy, (well im auto as of yet) you can screw up your front mount to... so make it quick!
-Jon
-Jon
well i just had someone look at it... and the engine cradle is pushed up really high.. is that part of the frame?? will that screw up nething if i drive it for a while? well thx for all the advice so far
Orangedragone
Oct 2, 2005 10:25 PM
SoLServiver
Jul 17, 2005 11:23 PM
