bad camgears adjustement
Since my valves were changed in my b18c5, is it possible that my camgears adjustement was mixed up when the dealer reinstaled my cams and aem camgears? What does a bad ajustment do on my engine??
aftermarket, the car feel's a little different.......I feel a bigger boost once I hit 7000rpm......mayby its because the dealer repolished and refaced the head?? How does the car should feel when I have a bad adjustment??
I checked the gears and intake is set at +4 and exhaust 0
I believe that when the dealership took my camgears off the camshaft, they did not replaced it at the good 0 setting. Damm teh cvar feel's so slow....I raced my friend stock rsx-s and was only able to put 1 car lenght on him dooing 1-2-3. His car is bone stock and I have 4-1 header, aem cai, cam gears, fpr, and underdrive pulley!! It was from a 20mph roll down!
I will have to find where my 0 degree adj his on the aem camgears and set them at zero untill I can dyno the car!!
Its weird, I only feel power at 7000rpm and the car dies around 8200 when b4 it was making power untill 8400. + the car feel alot slower then b4, is it possible that my camgears adj is so off that my intake cam is neerly not making any power??
so you guys tell me that if the car run good in general, that means that its ok?? Im pretty shure my car is slow!! I only putted 1/2 car lenth on a type s from a 20mph rolling start with all these mods I should be good for a 14flat high 13 with good condition when the s will run at best a mid 14
.....if they milled the head or "cleaned" the block, then you can throw your old adjustments out the window. You'll need a degree wheel to find out what your true 0 is.....
See if you can find out how much they took off the head and block, there's some conversion somewhere for adjusting/ compensating at the cam gears... I'll find it for you...
Drinker
has a list of ALL his setting for cases like this
