Leaking
Old Jan 20, 2009 | 11:56 PM
Gravey's Avatar
Default Leaking
Old Jan 21, 2009 | 12:01 AM
Fook_me_honda's Avatar
Default Re: Leaking
Your cam seal. Easy replacement.
Remove the valvecover, then remove the last farthest left piece holding the camshaft on. giggle it out. pull out the cap/plug/seal at the end. and replace it. common problem. I've heard aftermarket ones work better because they have layered o-rings that prevent the problem.
oh and no you don't have to remove the camshaft, i used to get that all the time when people asked me.
heres a pic of skunk2 replacements. theyre like 20-30 bucks though.
Old Jan 21, 2009 | 12:10 AM
Gravey's Avatar
Default Re: Leaking
Is it okay to drive it like that? I just noticed it.
Can this cause o2 sensors to go bad? because my o2 sensors are burned.
Old Jan 21, 2009 | 12:14 AM
Default Re: Leaking
Its fine. its not gonna burn out and spew oil everywhere, don't worry. And its impossible for the cam seal to be the cause of the O2 sensors going bad. I can't see any correlation to that.
And your O2 sensors are suppose to look burned, theyre sitting in exhaust gases all day, it get hot in there. If your not throwing a CEL for the O2's then theres no worries there. No need to fix whats not broken right.
Old Jan 21, 2009 | 12:18 AM
Gravey's Avatar
Default Re: Leaking
Thanks for the info.
Where can I buy that skunk2 one?
Old Jan 21, 2009 | 12:19 AM
Gravey's Avatar
Default Re: Leaking
And I'm throwing code p0133
Default Re: Leaking
Just google skunk2 cam seals. Or try jhpusa.com, theyre a reliable source.
Old Jan 21, 2009 | 12:27 AM
Gravey's Avatar
Default Re: Leaking
Thanks
Old Jan 21, 2009 | 04:39 PM
Gravey's Avatar
Default Re: Leaking
masijdm
Northern California
Oct 6, 2008 09:10 AM
Secret Chimp
Oct 15, 2007 12:14 PM
dogbiscuit
Oct 25, 2005 02:48 PM
s2k drifter
Mar 30, 2005 01:11 PM
VTEC-DA
Aug 14, 2003 08:08 AM
