Cluster doesn't light up/turn signals not working...
Old Jan 20, 2009 | 09:55 PM
EKwillister's Avatar
Default Cluster doesn't light up/turn signals not working...
I swapped my stock 96-98 climate control with one from an ek4. Didn't wire the stuff up yet, but I figured it wouldn't affect this stuff, so that's put to the side right now. After I turned the car back on, I started doing a check of stuff and my cluster doesn't light up anymore. The cel, battery, oil, ebrake, and srs light still work as well as the tach, spedo, fuel, and temp, but it's not lit up. My turn signals aren't working either now neither outside or on the cluster. I've checked the wiring and aside from the stuff that came off of the old climate control, it all seems to be wired just the way it was before. The fuse also seems to be fine, swapped it with on of the extra fuses and nothing changed so I'm really not sure what to do now. Do the harnesses from the climate control affect this stuff?
Old Jan 20, 2009 | 09:58 PM
94EG8's Avatar
Seagull Management
Default Re: Cluster doesn't light up/turn signals not working...
Did you plug in the hazard light switch? (the turn signals don't work without it)
Old Jan 20, 2009 | 10:08 PM
Oh really.. Haha, no I didn't. I have to rework some cables cause the hazard light is on the other side now. That shouldnt affect my cluster lighting up though, right?
Type1ej
Lighting
Feb 8, 2011 07:18 AM
bigBOI_92DA9
Mar 22, 2009 08:24 PM
JDM-EJ698
Feb 16, 2008 07:09 PM
go2sleep
Jul 6, 2006 10:06 AM
flatblack-h22
Mar 23, 2006 10:04 AM
