Water pump?
Old Jan 20, 2009 | 06:12 PM
juniorpopper's Avatar
Default Water pump?
92 jdm sir, B16a2 ... There is some noise comming from my timming belt/power steering/ac area.... sounds almost like how power steering sounds when its almost shot and the pump is whinning. but the noise does not increase when i turn the wheels, and the power steering fluid is full? the noise increases when accelerating... im just guessing water pump?? Car runs fine, engine temp is normal.. any help is appreciated. thanks
Old Jan 20, 2009 | 06:36 PM
trustdestruction's Avatar
Default Re: Water pump?
my p/s pump bearing just went out recently and i rebuilt the pump
the whining wasn't affected by turning the wheels, only by increasing RPMs. I think it's your power steering pump.
Also check for slipping belts first.
Old Jan 20, 2009 | 06:51 PM
I really hope thats what it is.. I plan to remove my ps/ac once summer comes around. and i was thinking of just cutting my p/s belt off to see if the noise stops but i would like to have p/s until i remove the whole setup. anyone else?!?! input!!!
Old Jan 20, 2009 | 06:53 PM
no need to cut the belt off... it takes like 2 minutes to remove...
loosen the two bolts on the left of the power steering pump, then loosen the top bolt until the belt is loose enough to slide off the pulleys
or you can take a funnel and put the small end by your ear and point the funnel at the p/s pump with engine running. then rev the engine via throttle body and listen.
Old Jan 20, 2009 | 07:27 PM
nbcivic's Avatar
do you have any leaks?
Old Jan 21, 2009 | 06:43 PM
no leaks what so ever...
Old Jan 23, 2009 | 02:36 PM
so it started making the noise explained louder today.. and started to sqeal.. and i smelt something burning. so i thought maybe the power steering pump was burnt out so i cut the belt.. i started it for 2 min and it was still making this noise.. i shut it off and took a look but could not see anything. i started it again and no noise? maybe a loose alternator belt?? someone?
Old Jan 23, 2009 | 02:46 PM
GYChris's Avatar
could be alternator belt or maybe bad timing belt tensioner
Old Jan 23, 2009 | 02:52 PM
Like I said...
Since it's not the p/s pump, just do this around the rest of the engine bay until you can locate the noise.
Old Jan 24, 2009 | 08:24 PM
so yah im not to sure.. the thing with the funnel didnt really work.. but its now just on and off squealing.. i felt the belts for tension and they seem not bad. the ac belt seemed to feel as if it had chipps out of the running surface? would that do it? even tho it would just be free spinning cuz i dont use my a/c right now since its winter
Old Jan 25, 2009 | 11:55 AM
bump bump
Old Jan 25, 2009 | 11:57 AM
nobody is going to be able to tell you what it is. it could be a million things. get under the hood, and figure out where the noise is coming from. nobody on here can do that for you.
Old Jan 25, 2009 | 11:59 AM
how bout only answer if you have something helpful... thats what im looking for
Inliner's Avatar
is the bottom bolt still in the alternator? same thing happened to me belt seemed tight but the bottom bolt had fallen out and when it revved somehow it would still squeel.
Old Jan 25, 2009 | 12:00 PM
thanks ill have to check that out.. this thing is driving me crazy
Old Jan 25, 2009 | 12:03 PM
It is helpful... that's what you have to do to locate a noise.
It could be any number of various bearings, belts, etc.
Try taking off all your drive belts and starting the engine. See if it still makes the noise. If it stops the noise, it is either the alt. belt or a/c belt, or the alt. or a/c compressor themselves.
Old Jan 26, 2009 | 02:43 PM
i figured it out.. the reasoin i couldnt look at it really is because its been minus 40 here for the last 2 weeks. anyways it was just my shitty a/c belt that was hopping out of the grooves and rubbing against my alt. belt. Smallest thing.
Old Jan 26, 2009 | 04:19 PM
green99civic's Avatar
I will say this man if you do end up putting a new water pump in u might as well put in a new timing belt also cuz they go hand and hand.
Old Jan 26, 2009 | 06:21 PM
yeah depends if i keep the b16, but if i do. id like to replace the timing belt/tensioner and water pump in the spring
Rotting Prelude
Mar 12, 2018 11:48 AM
wallendiaz
Nov 23, 2012 06:02 AM
integra15
May 27, 2011 04:27 PM
radeonboy
Oct 5, 2007 04:42 PM
CRXTAZC
Dec 11, 2006 12:41 PM
