95 accord water leak
Old Jan 20, 2009 | 05:06 PM
PeterK's Avatar
Default 95 accord water leak
I have a 95 Accord that has sprung a leak on the drivers side. Looks like a plug? bolt? is missing.
I can not see this very well as it is on the block? just behind the lower flywheel cover. The hole faces the firewall.
Any thoughts.
Is this a normal opening and the leak is from inside or under the timing cover?
This is a constant dripping and drains the block in a few minutes.
PeterK's Avatar
Default Re: 95 accord water leak
4 cyl V tec.
Old Jan 20, 2009 | 05:15 PM
TheMuffinMan's Avatar
He knows where you live!
Leaking what?
Oil?
Or by water do you mean coolant? Which should be a greenish color
Old Jan 20, 2009 | 06:00 PM
PeterK's Avatar
Duh on my part, it is water. Started as a slow leak.
Old Jan 20, 2009 | 06:02 PM
P_Adams's Avatar
Any thoughts.
What's on the tip of Muffinmans' tongue is that it's most likely the weep hole which is provided as a vent in the case of the waterpump shaft seal failing. I believe he will concure that the Water Pump is the culprit. It will require replacing. You might entertain doing the timing belt at the same time. It may have been contaminated.
P
P
Old Jan 20, 2009 | 06:16 PM
PeterK's Avatar
I thougt it might be a weep hole, and now that I look again you are spot on with the water pump. I will do both. can I do this w/o pulling the engine. It looks real tight to me.
Old Jan 20, 2009 | 06:17 PM
P
P
Jackpot
Old Jan 20, 2009 | 07:41 PM
P_Adams's Avatar
The Flat Rate Time Guide manual calls for about 2.7 - 3.2 hours for a properly trained (and equipped) tech to do the job. It is tight, but it can be done in-car. To the uninitiated, I'd plan for a day of it.
There should be a D.I.Y. timing belt primmer in the FAQ section of this forum.
P
Old Jan 21, 2009 | 04:27 AM
PeterK's Avatar
thanks
tjowers
Dec 14, 2009 01:01 PM
AtoZ
Jan 9, 2009 08:58 AM
accordman21
Nov 5, 2007 05:32 AM
EvenStar
Mar 2, 2007 11:54 PM
elijah
Jul 9, 2006 11:16 PM
