is there a way to figure out the year on jdm motors?
Old Aug 6, 2002 | 07:29 PM
clemens's Avatar
Default is there a way to figure out the year on jdm motors?
ok, some say to look for the head and the first numbers(like encircled) will indicate the year- is this an accurate way of identifying the year? i mean, isnt it possible that the head was made in 97 but it's for a 99-00 motor?
i also found this website http://www.allmotorhonda.com/techpag...anny_specs.htm
from the table, the spec r (96-97) has 4.4 final drive. 4.7(98+ spec r) final drive should have higher rpms when crusing on the highway, right? well my car's rpm is 3900 at 70 mph... does 4.4 or 4.7 final drive do that? i really want to know.
Old Aug 6, 2002 | 11:36 PM
The_Head's Avatar
Default Re: is there a way to figure out the year on jdm motors? (clemens)
*Disclaimer: this pic isnt mine, I took it from Katman's website*
This will tell you the year of the head at least
If you are cruising at ~3900 in 5th gear at 70 mph, you have the 4.4 FD
Old Aug 7, 2002 | 09:30 AM
clemens's Avatar
Default Re: is there a way to figure out the year on jdm motors? (xThexHeadx)
thanks.
i thought i had a 4.7 f/d thats ok...
mrtrex
Aug 31, 2004 10:30 AM
Atlas
Aug 26, 2004 04:11 PM
8400 rpm
Aug 4, 2002 08:33 PM
White Dragon
Oct 13, 2001 11:00 PM
DelsolVtec18
Sep 27, 2001 01:14 AM
