is this normal?
Old Jan 20, 2009 | 10:15 AM
j0keefe21's Avatar
Icon2 is this normal?
when im accelerating there is no difference between 3/4 throttle and full throttle... if its not normal what could it be?
Old Jan 20, 2009 | 10:16 AM
Unseen Racer's Avatar
Default Re: is this normal?
depends if your tranny is auto or manual. also depends on the gear. on auto tranny its pretty normal if your on 4th gear at about 3-4k rpm
Old Jan 20, 2009 | 10:28 AM
j0keefe21's Avatar
i would say 3rd gear 3 to 4 k but my car is pretty weak so maybe thats why i dont notice. i just didnt want it to be a timing problem of a air fuel ratio problem
Old Jan 20, 2009 | 10:56 AM
i forgot to say that it also depends on the speed that you are going.
you have a d15 right? if so, thats probably why if its stock
Old Jan 20, 2009 | 12:47 PM
j0keefe21's Avatar
i actually tested on the way to work. if i floor it before 4 k it will down shift but i guess my best example would be like 65 mph like 4500 rpmish 3rd gear. it wont pull any harder at full throttle than 3/4 throttle.
Old Jan 21, 2009 | 09:17 AM
so im guessing you have an auto tranny since you say that it down shifts.
well if your engine is the d15 that explains it. put at vtec head on it and switch to a manual tranny and your good. or you can just put a vtec head on it and it will still do better than its doing now
Steven5210
Honda Civic (2006 - 2015)
14
Oct 12, 2007 06:48 PM
Moshimoto racing
Feb 22, 2006 03:04 PM
aledee
May 31, 2005 07:13 AM
JforJonathan
Acura TL, RL & ZDX
Sep 14, 2004 07:01 AM
RallyRedGT-V6
Aug 30, 2004 09:09 AM
