automatic tranny question
Old Aug 27, 2004 | 08:55 PM
RallyRedGT-V6's Avatar
Default automatic tranny question
i guess i never noticed this before...but like from a stop...if i immediately go to half throttle, the car pulls ok to about 3 grand, and then distinctly pulls harder and sounds different [don't flame, but it sounds like a tiny little vtec crossover....and I KNOW IT ISNT...so dont flame]
is this where the stock torque stall is?
Old Aug 27, 2004 | 10:31 PM
mousiex113's Avatar
Default Re: automatic tranny question (96integra)
PROLLY YOUR TRANNY SLAMZ EACH GEAR. UR PROLLY GASIN IT TOO HARD FOR EVERY GEAR. "EVEN THOUGH ITS AN AUTO MATIC".
DOES YOUR RPM GO DOWN WHEN IT KICKS?
Old Aug 27, 2004 | 10:54 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: automatic tranny question (mousiex113)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mousiex113 &raquo;</TD></TR><TR><TD CLASS="quote">PROLLY YOUR TRANNY SLAMZ EACH GEAR. UR PROLLY GASIN IT TOO HARD FOR EVERY GEAR. "EVEN THOUGH ITS AN AUTO MATIC".
DOES YOUR RPM GO DOWN WHEN IT KICKS?</TD></TR></TABLE>
Holy ****, what the hell is this?? Lay off the CAPS LOCK TOO, y0!
Anyway, an automatic transmission can be very strange at times, which is why many people don't like it, they feel like they don't have full "control" over the car.
The ECU reads many things and uses these things to shift the transmission. These things can include load, throttle position, humidity, etc. Many things.
Can you describe the sound some more? I doubt it's something wrong. Most likely the tranny just shifting at an inopportune moment (i.e.: at a time you don't expect it to).
Remember, just like a manual transmission, an automatic has gear ratios. Depending on the rpm, gear, and speed, it may pull harder at times. Perhaps after you got the 3000rpm, there was more mechanical advantage due to the gearing, so you felt more of a pull?
Old Aug 28, 2004 | 10:52 AM
Default Re: automatic tranny question (shamoo)
its not shifting at 3...if i'm at half throttle it usually shifts around 5....but the exhaust tone just gets a little bit deeper, and it feels like the the tranny is locked up....similiar to when your engaging the clutch, from when it first starts to grab, to when its fully engaged
Old Aug 28, 2004 | 12:07 PM
njandrewg's Avatar
its a DOHC car....probably switching to the 2nd cam
Old Aug 28, 2004 | 12:42 PM
andylauiii's Avatar
Default Re: automatic tranny question (njandrewg)
my car at 3..when i press on gas at around 3000rpm..the rpm actually goes down for a bit... very strange..and i hate it...gotta do manual conversion soon...
Old Aug 28, 2004 | 01:08 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">its a DOHC car....probably switching to the 2nd cam</TD></TR></TABLE>
Holy crap, what the hell are you talking about?
I hope you are being sarcastic. Switching to the second cam????
Old Aug 29, 2004 | 03:41 PM
andylauiii's Avatar
Old Aug 29, 2004 | 04:10 PM
NeoGSR's Avatar
wow, i feel ill
Old Aug 29, 2004 | 04:25 PM
Code Blue's Avatar
Default Re: automatic tranny question (NeoGSR)
your tranny reacts differently depending on your throttle aggressiveness. when you say it pulls crazy, thats the transmission going into heavy load mode, almost every automatic car does the same thing when you floor the gas pedal. its perfectly normal man.
Old Aug 30, 2004 | 09:09 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96integra &raquo;</TD></TR><TR><TD CLASS="quote">... it feels like the the tranny is locked up....similiar to when your engaging the clutch...</TD></TR></TABLE>If you're holding the gas pedal at a constant position this whole time, then maybe it's the torque converter locking up. Maybe it's locking up at the wrong time? Or is it always like this? My '98 Accord is the only auto, but I can often feel it locking. It's more subtle than a shift, but if the road is smooth you can feel it.
smithenhiven
Apr 22, 2005 11:47 AM
malix
Mar 23, 2004 05:53 AM
Razor
Mar 24, 2002 02:54 PM
