eg, window rolls up SLOWWW!
Old Jan 20, 2009 | 09:08 AM
wdissident's Avatar
Default eg, window rolls up SLOWWW!
power window.my window barley rolls up and when it is really slow. when i put wd40 in the window trimming it rolls up like a champ. any questions? i checked the trimming and its fine. -thanks
Old Jan 20, 2009 | 09:13 AM
Hello Bart's Avatar
Default Re: eg, window rolls up SLOWWW!
i have the same problem... rolls up slowly... i use silicone spray... but it always seems to go away and roll up slowly... ive taken the window of the regulator and moved it up manually and it isnt binding only when the window is on the regulator.... dont know...
Old Jan 20, 2009 | 09:22 AM
wdissident's Avatar
ya wd-40 only last for a couple days. this is bullsh*t
Old Jan 20, 2009 | 09:30 AM
tercel95's Avatar
Welcome to Honda Motor Company...
Old Jan 20, 2009 | 11:43 AM
kcjohnnyboy's Avatar
one of my windows in my sedan does that too, i cannot figure it out either. i've tried silicone spray and that barely helps
Old Jan 20, 2009 | 11:51 AM
n0rt0n's Avatar
Silicone spray worked for my window. It use to be really slow also but after i sprayed it down with silicone, it now works like a charm ever since.
Old Jan 20, 2009 | 01:10 PM
NonovUrbizniz's Avatar
Loved
Yeah I'd spray the silicone into the top of the rubber channel the window rides up and down on in the front and the back then roll the window up and down repeatedly re-spraying if it binds.
Should work for at least a couple months
Old Jan 20, 2009 | 01:29 PM
switchjv's Avatar
yeah, silicone spray or a dry lube spray will work. you might want to remove the door panel and grease the tracks and rollers with some white lithium grease too.
raverx3m
Northwest (Sales)
Sep 19, 2010 08:05 PM
turbotuner
May 31, 2010 09:27 PM
damdash
Jun 24, 2009 05:08 PM
C_H_A_D
Dec 7, 2004 09:18 PM
91 HONDAsaurus rex
Sep 25, 2004 07:36 PM
