b16a2 obd2 in a 90 crx help!!!
Old Jan 20, 2009 | 08:49 AM
MonKK's Avatar
Default b16a2 obd2 in a 90 crx help!!!
I got a b16a2 and im gonna put it in a crx, and i want to make it obd1 so can someone help me here. what do i need to do to the the crx hf wires and/or the the stock b16a2 wires in order for everything to be obd1?
Old Jan 20, 2009 | 09:45 AM
wasabivtec's Avatar
Default Re: b16a2 obd2 in a 90 crx help!!!
Your easiest bet is just to send your hf harness out to rywire to lengthen the wires and change some of the plugs and get obd1 jump harness.
Old Jan 20, 2009 | 11:07 AM
h224thgensedan's Avatar
Converting to obd1 is not a hard task if you know anything about wiring. Plus you are allready mpfi. There are write ups all over on here if you do a little searching. To answer your question you use your hf harness and add to it. Get a obd1 ecu and a obd0 to obd1 conversion harness from Rywire. Jumper Harness comes with good instructions on which wire is for what.
Old Jan 20, 2009 | 12:54 PM
Intocable's Avatar
I just sent both harnesses to rywire and they did everything. If you don't know how you should definitely consider it
Old Jan 20, 2009 | 07:45 PM
MonKK's Avatar
thanks y'all appreciate the help. I know a little bout wiring. but everything is cake for me
Old Jan 20, 2009 | 07:59 PM
MonKK's Avatar
what kind of ecu should i use a obd1 pr3 or chipped p28 which would you guys recommend
Ef7-crx
Dec 18, 2018 09:39 AM
dracocrx
Jul 30, 2011 10:45 PM
:::SIRll_EJ1:::
14
Feb 18, 2010 04:14 AM
E_F_9
Dec 22, 2005 02:26 PM
DOHCarp
Feb 23, 2003 12:14 PM
