What turbo-wheel measurements
hi,
i have just bought a turbo believed to be a gt3071r, but on closer inspection it isnt,
i measured the wheels with a vernier caliper and these are results:
hotside wheel: 56.2mm
Coldsie wheel: 53.3mm
it looks like a gt3071r coldside housing with the 0.50 A/r stamp and its T2 flanged
and its oil & watercooled
Any help appreciated
Dave
Dave
your information is a bit incomplete. You've only stated the inducer measurement of each. If you could, please relay the complete information as shone below.
That will help us a bit more. Thanks.
okay, i pulled the housings off and got the exducer measurements,
compressor: 71mm
turbine: 60mm
so it appears to be a gt30, can anyone work out the trim from those measurments?
thanks
Dave
compressor: 71mm
turbine: 60mm
thanks
Dave
comp trim 56.3, turbine 87.7 from your measurements (your measurements are maybe a bit off on the hotside exducer) but seems like everything points to gt3071r. what makes you think that it isnt? they come t2 flanged and internally gated
RC000E
Dec 26, 2006 12:34 PM
viet_boi_racin
Aug 8, 2005 12:28 PM
