how to radio in ctr cup holder?
Old Jan 19, 2009 | 09:44 PM
redsidriver's Avatar
Default how to radio in ctr cup holder?
i have a 96-98 ctr cup holder and trying to figure out how to put the radio in it. i tried to test fit it once and it was slightly bigger then the whole. Ive seen pictures of others getting a radio in the bottom cup holder of 96-98 usdm civics . ive searched and have been unlucky with it . please direct me to a correct thread or post pics please
Old Jan 21, 2009 | 08:39 PM
Default Re: how to radio in ctr cup holder?
bump please
Old Jan 21, 2009 | 08:47 PM
andoxviii's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-install-cd-player-lower-slot-96-00-a-2311587/
JDM CTR cupholders are the same idea. Remove the pocket and use the brackets that hold the pocket in to mount the radio.
Old Jan 21, 2009 | 08:58 PM
yes i took the pocket out but the radio didnt even fit in the whole . should i maybe switch to usdm one?
Old Jan 21, 2009 | 09:02 PM
andoxviii's Avatar
Are you using an OEM radio or aftermarket?
Old Jan 21, 2009 | 09:04 PM
aftermarket. isnt it smaller then oem
Old Jan 21, 2009 | 09:05 PM
andoxviii's Avatar
Make sure you don't use the "sleeve" that comes with your aftermarket deck. Just put screws right through the bracket on the cupholder piece and into the deck.
Old Jan 21, 2009 | 09:06 PM
hm i think that might be where i went wrong ill try it sometime next week when i get time thank you
or ill just make the whole bigger haha
Old Jan 21, 2009 | 09:07 PM
andoxviii's Avatar
I remember I talked to you in an old thread I made on the same subject:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/96-00-jdm-ek9-cupholder-review-2457607/
Maybe the top picture on that thread will make it easier for you to visualize. It shows the bracket I'm talking about.
Good luck
Old Feb 5, 2009 | 03:32 PM
well finally found my cup holder from storage and the stereo fits . not perfect but it will do . now to find screws that will fit the stereo. i dont remember if the stereo came with the bolts or not but i wouldnt know where they r . anybody know what kind of bolts they are?
also has anybody tried taking off the face cover that comes up when the cup holder opens. i think it will fit better without it. well see
Old Feb 5, 2009 | 03:39 PM
andoxviii's Avatar
I'm not sure which screws they are, but make sure that if you are going to experiment that you don't try screws that are too long. If you do, you may damage something inside the stereo.
As for the lid, I have been thinking of doing this as well. If you have any luck, let me know
Old Feb 5, 2009 | 05:19 PM
en00be's Avatar
thats sweet
Old Feb 5, 2009 | 06:04 PM
well found the screws that came with the deck and they worked perfect . now working on getting the lid off looks like it just has a rod going through keeping it atached to the cup holder . trying to push it out but its barely budging. maybe need some wd40 to lubricate it . after that should be easier if not maybe ill just break it off.it hits my radio when it opens and id prefer that it wasnt there at all .maybe ill figure it out next week
Old Feb 5, 2009 | 07:49 PM
after about an hour of trying to remove the flip up part of the cupholder it just wasnt budging. i used wd40 to lubricate it but the rod just didnt budge . sooooo i just broek it off. i used some wire cutters to cut the 3 tabs off that keep it on and im happy with it ima try and get some pictures. not saying its for everyone but it better suites my needs
Old Feb 5, 2009 | 08:43 PM
what do u guys think . not in the car but its done . easier then i thought and its not perfect but like i said before it works and now i can move on to my plans for that the double din space where my radio used to go .
Old Feb 6, 2009 | 12:14 AM
andoxviii's Avatar
Nice job.
I was going to put my deck down there but got a double-DIN Pioneer screen instead.
Its good to know the lid fix can be done though. I will definitely be doing that if I put a standalone equalizer down there like I plan.
Old Feb 6, 2009 | 12:31 AM
bmoua's Avatar
OP, its not worth the trouble trust me.
Old Feb 6, 2009 | 04:25 PM
its easier when you have a remote for the stereo besides ive wanted that space in the climate control for 3 gauges for the longest time.
Old Feb 6, 2009 | 04:34 PM
andoxviii's Avatar
Yeah, that double-DIN slot would be a nice area for gauges since there's a lot of room and its at eye-level.
I've also been thinking of installing a couple gauges by the cupholders...atleast a voltmeter or something. Do you think there would be room if I removed the pocket?
noggin617
Jan 12, 2013 09:05 AM
The Droogan Leader
Audio / Security / Video
Jul 16, 2009 06:50 PM
skeeter019
Apr 18, 2007 11:21 PM
SiB16A
Feb 10, 2006 01:19 PM
1hotcivicSi
Apr 3, 2004 09:21 AM
