Need help with brakes
i bought a 99 integra from my buddy that had jdm 5 lug on it well i didnt feel like buyin axles and limited wheel choice so i sold it.
bought everything to put 4 lug on my car (came off 99 gsr)
i put everything on but brakes go to the floor? i have bleed them over and over and still nothing i made sure the calipers are not froze and plenty of fluid. need some help?
You sold the 5 lug conversion cause you didn't feel like buying axles and limited wheel choice? What is so hard about buying axles and wheel choice is almost the same.. You cant use standard OEM si wheels, gsr wheels, etc... IMHO it probally wasn't worth the labor of swapping the stuff out.. I would of kept the 5 lug, but whatever.. to each is own
What bleeding procedure are you using?
You might haft to bleed the ABS.
https://honda-tech.com/forums/acura-integra-6/trouble-bleeding-abs-1488415/
yeah because it was jdm 5 lug damn 36 mm spline bull ****... and i was offerd a price i couldnt refuse so i sold it.. but thanks on the heads up about the abs. imma try in tommorow if it warms up a lil
money's money though
stop pumping the brakes
look up a faq on brake bleeding
pumping aerates the fluid and goes against what you are trying to achieve
steady pressure down on the pedal as someone cracks open the bleeders, closing them as the pedal reaches the floor...really goes much better with 2 people
EKtypeRhaTcH
Northern California (Sales)
Oct 14, 2011 09:08 AM
Hulk_EJ8
Suspension & Brakes
Nov 14, 2005 07:54 AM
