Quick question PR
Old Jan 19, 2009 | 06:24 PM
90.EF.Si's Avatar
Default Quick question PR
i theres compression coming out the vavle cover where the oil hole is on top you need piston rings? and if you need a head gasket and the water mixed is it possible its only the head gasket?
Old Jan 19, 2009 | 06:27 PM
ef_junky's Avatar
Default Re: Quick question PR
there will usually always be blowby.... and what bout the head gasket...
Old Jan 19, 2009 | 06:28 PM
90.EF.Si's Avatar
well i got the head off the block (mini me ) and i know it needs a head gasket, but i remember it having compression coming out the top and steamy (water?) so i was j/w if i needed to change the rings while im at it
Old Jan 19, 2009 | 06:39 PM
90.EF.Si's Avatar
bump bump
Old Jan 19, 2009 | 06:58 PM
Jonknee's Avatar
Dude im confused, are you saying that steam is coming out of the valve cover
jdmitrdc2
Apr 15, 2009 11:31 AM
mackadocious
18
Jul 2, 2008 05:57 PM
silentdaredevil2
Nov 24, 2005 12:29 PM
.::Lee::.
Feb 17, 2004 08:50 PM
Screamer
Apr 15, 2003 05:50 AM
