thermosensors : why oh why?
Old Jan 19, 2009 | 05:07 PM
HTautodc's Avatar
Default thermosensors : why oh why?
it's been puzzling me for the longest time possible, believe me. why are there 2 thermosensors on my 1990 civic 4-door dx?
you see, i have this problem : i think that my thermostat is opening too early (i see my temp gauge 1/4 of the gauge most of the time). but my rad fan doesn't turn on until about half of the gauge. so i'm planning to change the thermostat with an OEM one (my brother-in-law said he changed it to an aftermarket and colder thermostat when he changed it before).
so that i won't again have the same problem (rad fan turns on late and not turning off until you shut the engine off), i'm also replacing teh thermoswitch (thermosensors). i'm confused because i don't know which thermoswitch should i replace
anyone? thanks
Old Jan 19, 2009 | 05:45 PM
Jonknee's Avatar
Default Re: thermosensors : why oh why?
There are two thermoswitches? Mine only has 1 by the thermostat, and then a coolant temperature sensor, that's it.
Old Jan 19, 2009 | 07:20 PM
xci_ed6's Avatar
you have 3...kinda.
1-wire under dizzy= for gauge
2-wire under dizzy= for ECU (aka: ECT, engine coolant temperature sensor)
2-wire on back of block=fan switch
Old Jan 19, 2009 | 09:06 PM
HTautodc's Avatar
according to the online honda parts, #23 and 24 are the thermosensors and #22 is the temp sending unit?
if the rad fan is turning on late (or is it the thermostat opening way too early), what parts should i replace? i'm so fed up already of my rad fan not turning off once it turns on (unless you shut the engine off). it's so noisy
Old Jan 20, 2009 | 10:45 AM
4drEF's Avatar
Keyboard Humorist
23 controlls the fan.
22 is for the cluster.
24 is for the ECU.
Old Jan 20, 2009 | 03:12 PM
alx_90ef's Avatar
does anyone know what the connector for #23 look like?
Old Jan 20, 2009 | 03:23 PM
4drEF's Avatar
Keyboard Humorist
I'll keep looking for a pic, but if you are working on it now this might get you through -
It's an ugly big rubber boot. The actual connector leads can slide in and out from the boot. It makes no difference which pole on the switch you hook the connector leads to - it's just a switch and turns on and off.
Old Jan 20, 2009 | 03:46 PM
alx_90ef's Avatar
ok so heres the thing. i have a d15z1 block.
does it only have # 21?
cuz if it has both im ****en blind
Old Jan 20, 2009 | 05:49 PM
4drEF's Avatar
Keyboard Humorist
Check up on the thermostat housing for that engine
Old Jan 20, 2009 | 05:53 PM
alx_90ef's Avatar
thats were the rad fan input is?
Old Jan 20, 2009 | 06:07 PM
xci_ed6's Avatar
yeah, shoulda mentioned the swap
Old Jan 20, 2009 | 06:48 PM
alx_90ef's Avatar
so like....
i still cant find that input
Old Jan 20, 2009 | 07:37 PM
HTautodc's Avatar
4drEF, what do you think is wrong in my car? once the rad fan turns on, it doesn't turn off unless i shut the engine off thanks
Old Jan 21, 2009 | 02:15 AM
xci_ed6's Avatar
make sure the thermostat is installed with he air bleed pin at the top.
Old Jan 21, 2009 | 08:25 AM
4drEF's Avatar
Keyboard Humorist
Is it cooling down properly or is the fan actually on for a reason?
Only things that come to mind are the fan switch or a sticky relay.
Old Jan 21, 2009 | 09:15 AM
alx_90ef's Avatar
so # 23 on the d15z1 should be under the thermostat housing for my engine? cuz i had to figg another fan cuz the rad fan never came on=/
Old Jan 21, 2009 | 07:31 PM
HTautodc's Avatar
thanks, man. i think i'll have to flush my cooling system first just to be sure
crxguy406
Aug 20, 2012 06:36 PM
TshingY
Jan 25, 2010 12:59 PM
electric-boost
Dec 11, 2006 08:37 PM
si 1
Jan 2, 2006 04:48 PM
89 CRX SI
Apr 19, 2004 07:20 AM
