Rear trailing arm bushing question.
I have a 93 Civic HB with the rear trailing arms/brake swap from a 93 Integra. The stock trailing arm bushings were needing to be replaced. So I purchased some performance bushings for a 92-00 civic because I thought that they would be compatable, but the bushings seem to be to small around. What is the differance between EG civic trailing arms and 90-93 integra trailing arms? Are the the bushing the same size?
we just did this to my buddy's car a few days ago. you're going to need to reuse the 90-93 integra shell and pin. the way we did it was pressed the bushing out and set it on fire till we could get the rubber off the pin and shell. then we rounded off the ends of the pin and pressed it into the bushing. once the pin is in the bushing it'll force the rest of the bushing to expand into the shell. we used es bushings goodluck
cangrin
Jan 20, 2009 09:50 AM
Timberland237
Nov 20, 2006 08:00 PM
.:TNN:RumbleN:.
Jun 4, 2004 06:38 AM
RacerBoy
12
Apr 3, 2003 08:06 AM
