1999 Honda Accord knock sensor
I searched on google to no avail for the location of the knock sensor. I found it myself and thought I would help those in need since later model Hondas seem to require the removal of the intake manifold.
The knock sensor is located directly above the oil filter. It requires a 24mm socket long enough to cover the end. There is no need to remove anything else in order to access it.
Obviously, I can't diagnose the specific reason your check engine light came on, but my knock sensor simply broke in half requiring a replacement - $130. A common problem I saw in my search was wire faults needing no replacement.
Good luck.
Good luck.
brokenbus
Apr 29, 2016 03:00 PM
Leviata-N
Mar 13, 2006 11:36 AM
