gas problem
Old Jan 19, 2009 | 03:01 PM
cheng_sayaovong's Avatar
Default gas problem
i have d16y7 in my 4dr. for some reason it eats alot of gas. its running on a pr4 ecu and my friend told me that that's the reason why it's eating so much gas. i've tried a dx ecu, its starts up fine but a couple a seonds late it dies. what do you think the problem is? help me out!
Old Jan 19, 2009 | 03:05 PM
trustdestruction's Avatar
Default Re: gas problem
Were you trying to use a manual ECU on an automatic transmission vehicle?
If not, maybe something was wrong with the ECU.
You should definitely be using the DX/LX/CX ECU, but it has to correspond to your transmission.
Old Jan 19, 2009 | 03:09 PM
the car was originally auto but was converted to stick and yes i'm using the correct ecu.
Old Jan 19, 2009 | 03:27 PM
I suspect something may be wrong with the D16Y7 ECU you tried using. If the D16Y8 ECU runs the car fine, and the D16Y7 won't, there must be something wrong with the D16Y7 ECU you tried using.
Old Jan 19, 2009 | 03:39 PM
the ecu gotta be good cause it came outta of a running car. could it possibly be the timing thats causing it?
Old Jan 19, 2009 | 03:41 PM
idk
i'm stumped
ECU works in another car, doesn't work in your car, but a different ECU works in your car... all when it's suppose to work with the ECU that doesn't... just doesn't make sense
nick91civicsi
Engine Management and Tuning
Oct 25, 2009 03:27 PM
§95HATCH§
May 16, 2009 07:19 PM
Kelley99
10
Jan 21, 2009 05:48 PM
nmhuntr
May 16, 2008 01:28 PM
Frosty_spl
Nov 18, 2001 05:46 PM
