1994 civic ex... surging problems. help
Old Jan 19, 2009 | 01:40 PM
thannon2's Avatar
Default 1994 civic ex... surging problems. help
So, I've changed just about anything you could imagine trying to fix this problem. Although it's better it's still there... It seems to do it really bad when I stop and turn off my headlights. Anyone have an idea what could cause this... my check engine light and horn do not work either... Could this all have something to do with the alternator?
Old Jan 19, 2009 | 01:52 PM
thannon2's Avatar
Default Re: 1994 civic ex... surging problems. help
Old Jan 19, 2009 | 04:19 PM
thannon2's Avatar
Old Jan 19, 2009 | 04:55 PM
dividedas1's Avatar
have you checked the dizzy?
maybe you have a v. leak some where. does your engine almost die out?
do your headlights flicker? or radio ever cut out? (if yes then check the alt)
the cluster might have burnt out bulbs, not too sure about the horn though
Old Jan 19, 2009 | 05:18 PM
slimjimming6688's Avatar
sprey some brake clean in to the idle air controle valve, clean out your map sensor
Old Jan 19, 2009 | 05:23 PM
thannon2's Avatar
the engine almost dies when i first crank it... the radio never shorts out.
Old Jan 19, 2009 | 05:26 PM
try spreying carb cleaner through the iacv
Old Jan 19, 2009 | 05:38 PM
thannon2's Avatar
I've replaced the IACV.... i'm thinking it might be the MAP, that would cause shorting?
CHU-JDM-DC2
May 10, 2014 07:57 PM
ihonda
12
Feb 6, 2012 04:55 PM
dfjr0926
Mar 10, 2011 05:16 PM
hondabooster
10
Apr 15, 2008 11:45 PM
sloaccrd
Jun 29, 2005 10:11 PM
