rear brake pad install?
Old Jan 19, 2009 | 11:26 AM
turbo-crx's Avatar
Default rear brake pad install?
Ok i have no idea how to get the brake pads to sit into the retainer clips. I have never worked on brakes before and am lost on how to do it. I have the helms manuel and it does not say exactly how to put the pads into the retaining clips. Anybody have any pics,links, or videos on how they go on? thanks.
Old Jan 19, 2009 | 11:41 AM
Ermil's Avatar
Default Re: rear brake pad install?
Do you have the correct brake pads?
Old Jan 19, 2009 | 12:27 PM
Tyson's Avatar
if theyre the right pads, they just fit right in. the retaining clips must be in the original positions. meaning the two lower retaining rings cannot swap sides of the rotor, theyre not the same shape if you look closely.
btw, do NOT try to push the REAR caliper piston back in. you MUST screw the piston in as its how it accomodates the parking brake mechanism.
Old Jan 19, 2009 | 02:03 PM
turbo-crx's Avatar
yes they are the right pads. I twisted the piston back in with a flat edge till at sat flush like its suppose to, and thats what the book says to do. i dont understand the concept of the damn reataining clip and how it holds the brake pad in place. I tryed for hours trying to get the pads to stay in the retaining clips.
Old Jan 19, 2009 | 02:34 PM
Tyson's Avatar
i have no clue why you have difficulties accomplishing a simple task then.
pics?
Old Jan 19, 2009 | 03:32 PM
turbo-crx's Avatar
pics?
your telling me. Do i need to remove the caliper mounting bolts or just the 2 bolts that hold the caliper on?
dr_spock
Honda Civic (2001 - 2005)
Sep 20, 2008 10:22 PM
garyc17
Jan 14, 2008 05:29 AM
athoughts
Nov 17, 2005 03:12 PM
LudeChild
Nov 16, 2004 05:27 PM
89JDMcrx
11
Oct 18, 2004 10:51 AM
