Auto Manulal Conversion Key Problem
Old Jan 19, 2009 | 04:53 AM
Jimster480's Avatar
Default Auto Manulal Conversion Key Problem
I did an auto to manual conversion, but what do i have to wire together in the 14 wire plug in order to take the key out?
Old Jan 19, 2009 | 06:16 AM
Jimster480's Avatar
Default Re: Auto Manulal Conversion Key Problem
cmon ppl. need this solved ASAP.
Old Jan 19, 2009 | 07:08 AM
94EG8's Avatar
Seagull Management
What year civic? The '92 - '95s have a blue shift interlock box that bolts up to where the clutch pedal goes, simply unplug and discard. Not sure about the '96 - '00 civics, although you should be able to remove the actual interlock on the ignition switch.
Old Jan 19, 2009 | 10:16 AM
Jimster480's Avatar
oh. Supposedly there is a way to wire it to some out lol.
Old Jan 19, 2009 | 03:50 PM
trustdestruction's Avatar
is this what you need?
(bottom of thread's first post)
http://hondacivicforum.com/forum/showthread.php?t=31774
Old Jan 19, 2009 | 04:50 PM
sicones's Avatar
There is very small 2 pin connector that plugs into the interlock solenoid around the ignition cylinder, find that and unplug it.
Old Jan 20, 2009 | 04:05 AM
Jimster480's Avatar
that didnt work.
CW-ITR
Nov 5, 2006 09:05 PM
getnasty
Jan 5, 2006 04:40 PM
DriveSlowHomie
Oct 25, 2004 09:07 AM
D_TY3
Sep 30, 2003 09:27 AM
JDMvtecDRAGSTA
Mar 24, 2002 10:47 PM
