Help... my heater stopped working!!!
Old Jan 18, 2009 | 09:43 PM
dohc-father's Avatar
Icon6 Help... my heater stopped working!!!
its starting to get cold as s**t here in philly and my heater stopped working. long story short... i unhooked the climate control because i was installing a new radio in my car. i had a hard time pulling the old aftermarket stereo out so i pulled the whole bezel out (cant think of the name of it right now) i unplugged all the harnesses in order to manuver behind it and after the stereo was installed, i plugged everything back in. everything works fine but the heater doesnt blow hot air. i checked the fuses and they are good. is there anything im missing?
thanks in advance.
Old Jan 18, 2009 | 10:10 PM
1993_EG6's Avatar
Default Re: Help... my heater stopped working!!!
Check the plugs and the wires maybe is not plugged up right.
Old Jan 21, 2009 | 07:06 AM
still not working!!!! help im freezing!!! lol
Old Jan 21, 2009 | 07:35 AM
RobbieG35's Avatar
12 Years Strong
Did youmake sure that the water valve is opening up when you move the level from hot to cold?
Old Jan 21, 2009 | 08:47 AM
Black4thgenEF's Avatar
The cable that changes the settings from hot to cold on your climate control can easily pop out of the clip that holds it, making it not work. Look under the passenger side dash and move the switch back and forth to see if this is the problem.
dwuknoit
Jan 17, 2008 05:41 PM
philkehn
13
Sep 21, 2006 12:02 PM
projectej8
Aug 14, 2005 02:43 AM
type gsr
Oct 19, 2004 07:23 AM
technine
Sep 16, 2002 01:28 PM
