Suspension & Brakes Theory, alignment, spring rates....
Spring Perches Koni
Old Jan 18, 2009 | 06:59 PM
bopbop93030's Avatar
Default Spring Perches Koni
Ok.
which perch do I need to put the GC, high or low?
I have an Accord and the Koni yellows for my car has only 2 for the front and 3 in the back.
Since the top perch is for lowering springs then the lowest perch is for GC?
I Need to have more shock travel in the front. Already cut my bumpstop in half.
So if I lower the perch in the front will I have more travel?
Thanks!
Old Jan 19, 2009 | 05:14 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Spring Perches Koni
You already asked this question earlier. Leave the Koni circlips in the stock location. Also you should NOT be using the Koni-supplied spring perches. The GC sleeves should fit directly over the circlips on the Koni shocks. This is how you installed it, right?
Deminmatthew
Suspension & Brakes
Aug 5, 2012 06:26 AM
kevinm1981
Suspension & Brakes
18
Jul 10, 2010 02:05 PM
Myh4tch
21
Jan 20, 2004 04:15 AM
jaM3s Bond
Mar 6, 2003 09:57 AM
slimbo
Sep 23, 2002 05:21 AM
