My Car Is Eating Main Relays
when you say eating main relays... are you getting a hot-soak no-start like a typical main relay failure? Do you have fuel when you attempt to restart? I've rebuilt many main relays by removing the cover and resoldering cracked spots on circuit board. you can too, but you must be very careful not to solder the pre-existing spots together.
I would think that you are hiding the real problem by changing the main relays. Have you inspected the main relays for a failed solder connection? or tested the ones you have removed?
damn im going thru EXACTLY the same problem.. i re-checked all the grounds even did a test light on all the fuses...still getting no fuel no spark, constant check engine light the ignition doesnt even beep when u put the key in wit the door open...
im having the same problem besides my check engine light dont turn on at all no spark no fuel!????? help! doe u think it coulb b the e.c.u???
Jimmy
14
Dec 21, 2004 04:47 PM
